Show me your switches! Pics please...
One thing you may want to keep in mind while deciding where to mount the switches is how easy it would be to replace the piece you are going to drill a hole in. I always try to choose a location where the plastic piece being drilled is small, cheap to purchase, and easily to replace. If you drill a hole in a portion of the dash that is large, it will be very costly to replace if you decide you want to sell the Jeep or trade it in and need to remove the accessories.
GREAT THREAD!
TIA
Just finished wiring for oem fogs in my mid-width. I didn't have enough wire to run things like I wanted, but they're hooked up and work with low beams only. I didn't install a switch, but I may later. I'm going to completely re-wire this weekend and will take pics for those watching along at home. I'll start a new thread when i do. (sorry for the temp hi-jack)
Found this in another thread I think it's made by cooltech
You can get them in several places. I mainly get mine at west marine or boater's world. Any good boating place should have them. not cheap, but I think look best. The switches come seperate from the mounting panels. They wouldn't fit in the lower console unless you use the daystar panel like BodyGuy.
