Silent horn
Old 07-18-2008, 04:25 AM
Davidengbe's Avatar
Default Silent horn
There's no sound from my horn anymore... checked fuse, checked connection by the horn itself. Nothing seems wrong. Anything else to check?
Old 07-18-2008, 04:57 AM
Octo's Avatar
Voltage to the horn.
Have someone hold down the horn button (or set off the alarm or panic) and try to measure voltage to the horn.
If you see voltage then your horn is toast, if you don't it is time to visit the stealership. If you do see voltage then it is time to upgrade to a better horn.
Old 07-18-2008, 05:03 AM
Davidengbe's Avatar
Good idea!
Actually, now I remember that the horn honked loudly a while ago, when putting back the cables to the battery after some welding...
Old 07-18-2008, 05:17 AM
dyolfknip's Avatar
Originally Posted by Davidengbe
Good idea!
There are 2 fuses for the horn. 21 and 23. Check em.
Also there is a relay in the fuse box. If you set of your panic button you should here it clicking. If you dont then you know it maybe be a bigger problem.
Old 07-18-2008, 08:32 AM
Davidengbe's Avatar
Ok, tested to measure voltage during pressing the horn at the wheel, no juice.
Checked both fuses, they're ok.
Do you know which relay it is? (Number?) Panic button? Where's that?
Old 07-18-2008, 08:35 AM
deconstructionist's Avatar
On the key FOB
Old 07-18-2008, 10:15 AM
Davidengbe's Avatar
Have manual locks...
Old 07-18-2008, 09:09 PM
Octo's Avatar
I'm pretty sure that the two fuses in question are 22 and 23.
I just replaced my stock horn with a air horn and found that these two fuses were identified for the horn. When I pulled either one of them the horn stopped working.
Double check the list of fuses on the under side of the fuse panel.
Old 07-19-2008, 12:35 AM
Davidengbe's Avatar
You're correct. Those are the numbers. And - they're ok... Ok, guess the dealer has to look into it...
Old 07-19-2008, 09:05 AM
Sgt P's Avatar
Thumbs up Silent Horn!?!?!
This is a great thing!
You can "lay on the horn", and not wake the neighbors!!!
Quick Reply: Silent horn
