Splicing into ignition switched power
Old 09-25-2010, 01:13 PM
PainKiller's Avatar
Originally Posted by Vernnz
Also there is the M8 Heated Seat fuse tap in the TIPM. Key positions are Off, Accessory (Radio, Power Windows, etc), Run (Gauges and Error Lights lit, A/C fan on, etc) and Start (Momentary engine crank). The M8 location is only energized in the Run position.
x2 and also the M6 slot
Old 09-25-2010, 05:26 PM
bigbluejk's Avatar
oooooohhhhh..... sorry. I thought you just wanted a ign. now I see. Hell yea, use the m8. Good spot.
Old 12-02-2010, 07:20 AM
Dog Doc's Avatar
This may be a stupid question, but how do you utilize the M8 spot for power? Is there a special fuse that you can plug in that will allow you to tap into it?
Old 12-06-2010, 01:03 PM
wmphoto's Avatar
Just so I understand this... The M8 or Pink and Yellow wire...
Is the one I would say hook up a switch for say a winch that I wanted only to have power, when i flip the switch... and only when the vehicle is running...
Correct?
Old 03-11-2019, 02:00 PM
Creighton's Avatar
Default Fuse Tap for M8
Quick Reply: Splicing into ignition switched power
