sPOD worth it?
sPOD worth it?
Hey everyone! I'm new to the jeep community and have been doing some research in regards to auxiliary lighting and wiring. I'm a bit anal when it comes to things looking neat and clean, so the idea of this sPOD having only one wire that taps into the battery seems right up my alley! I was wondering if anyone here has installed it, and if so, what are your opinions. Is it worth the $$, is there a cheaper just as good option, etc? Thanks
I was in the same boat a while back. First let me say I am a tight a$$. I liked the Spod but I could see spending all that money for something that I could build or get cheaper. I went the Bussmann route. There is a guy in Az. that makes them up. They work great. I went with the Weather Tight Relay Box because it has relays already in it. here is a link to his site. Relays, Fuses & Breakers | PMA4x4.comPMA4x4.com
here are a few pictures of what I did.
The best part about the sPOD is the in-cab controller. It looks factory in the early model JK interiors, and you can make it look factory in the late-model JK interiors by replacing the Contura II switches with Contura V switches. Go to OTRATTW.com and order either the silk-screened toggles for the switches the sPOD comes with, or order the entire Contura V switches with the laser-etched toggles if you want to replace the entire switches. Advantages of either are they are professionally labelled with each switch's function. Advantage with the Contura Vs is that the laser-etched toggles are back-lit and nicely lit--extraordinarily factory. Add the sPOD controller (there are four variants--make sure you get the one with the features you want) with the gauge hole opening and you can add a gauge of your choosing. I found a VDO oil pressure gauge that is a nice complement to the JK dash gauges.
Now, the worst parts about the sPOD controller:
And because moving pictures are fun, fast forward to 0:38 for water fording.
https://www.youtube.com/watch?v=aLkNU8d8w-c
- Limited to 50-amps total, 30-amps per circuit, six circuits (thus had to wire overhead lights to two separate circuits).
- Turns on things well, but not designed to turn off things (thus had to add extra relay for fan motor control).
- Not waterproof. For the money you pay, it should be waterproof. But, I've never had a problem with it, and I do ford deep stuff.
On off
Attachment 557541Attachment 557542
I have a question for your negative comment about it not turning off items well.
So for me to turn off my lights and for example an air compressor the jeep has to be turned off to shut that item off? When I hit the switch from on to off it dosnt turn it off? Maybe I misunderstood it.
Thanks
BK
Here is one option I've looked at. Only thing that makes me nervous is the box with all the connections. Is it going to hold up to 100 degree day on trials.
http://www.youtube.com/watch?v=OYMe2xTvyUQ
Spod is worth every penny!!!!!!!!!!!
Yes you can build one similar but by the time you spend building and buying all the parts you paid for the Spod. Plus this unit looks like it came from the factory on the Jeep. Also it turns off all accessories once the voltage drops to 10 volts that way if you leave the lights on you wont have a dead battery. Don't question your self just do it!!!!!
