Step By Step Installation of Rigid Dually LEDs using BDF Fog Light Bracket
Old 04-08-2012, 05:03 AM
MFX
MFX's Avatar
great write-up but one thing missing, night shots
Old 04-08-2012, 05:13 AM
Matthewd5's Avatar
Yeah I need to take some and add them
Old 04-08-2012, 07:07 AM
MFX
MFX's Avatar
Where did you get the brackets from? I'm trying to google it but I'm coming up empty. Did you get a package deal from a vendor for the lights and brackets?
Old 04-08-2012, 07:10 AM
Matthewd5's Avatar
I got the lights and brackets from northridge4x4.com ask for David he won't stear you wrong
Old 04-09-2012, 08:03 PM
JKU2007's Avatar
Here are some night shots from 20 feet away from the wall.
Here are the rigid dually flood lights
Here are the rigid dually spot lights
Old 04-23-2012, 08:57 AM
TNGatorBrad's Avatar
Thank you for the write-up. Those lights look great with a nice beam pattern.
Old 05-29-2012, 06:46 PM
Butler20's Avatar
would you recommend the spot or floods for the fog lights?
Old 05-29-2012, 07:00 PM
Matthewd5's Avatar
I would definitely recommend the spots, the floods spill all over the place and blind everyone
Matthew
Old 07-21-2012, 01:47 PM
Tylerm78's Avatar
Just ordered a set of Dually spots and with the BDF brackets and Truck-lites from Northridge 4x4.
Plan on just wiring in the Duallys in as fogs with the factory wiring. I thought about using a relay and the factory switch to activate them. I wondered if anyone has tried to mount a switch inside to run them independent or off the factory switch? If so would I just run the factory wire and the new switch wire to the same post on the relay? I'm pretty comfortable with wiring just haven't had much experience with custom wiring involving relays.
Basically I want them to act like the stocks with the switch in one position and turn on independently in the other position. Any input as to what the best way to accomplish this would be appreciated.
Old 07-22-2012, 04:14 PM
Tylerm78's Avatar
Any wiring gurus have any input? In my head I think it would work.
Quick Reply: Step By Step Installation of Rigid Dually LEDs using BDF Fog Light Bracket
