Stock Interior (Weather Sealed???)
Old 07-22-2008, 04:29 PM
PowerPlay's Avatar
Default Stock Interior (Weather Sealed???)
I know it's probably been asked several times but it's a simple question and a simple answer should do.
Is the MyGig system and all the controls on that panel (Climate control, etc.) water tight? I want to line the bottom of the jeep with LineX and I would like to be able to spray it out with a hose when it gets dirty, but if the electronics aren't sealed then I cant do that...
I know a buddy of mine had a 1998 Jeep and his were sealed, but I want to make sure and not just assume mine is too..
Thanks for any reply.
-PP(TM)
Old 07-22-2008, 04:51 PM
Gypsy's Avatar
Don't believe it is... I have a 2007 but I do believe I read in the 2008 manual that you should not let water get into your electronics...
Old 07-22-2008, 05:33 PM
Jordo89's Avatar
absolutely not. please give me your mygig before you spray it with water. spraying the floor out with water won't hurt anything, but don't spray your dash/ console. there are electronics everywhere in these things and they're far from water tight...
Old 07-22-2008, 07:12 PM
saltman's Avatar
for the record also. The 1998 jeep was also not sealed. They never have been.
Quick Reply: Stock Interior (Weather Sealed???)
