Switchable Aux Reverse Lights - Schematic Feedback Requested
Very interested in outcome. I was told it may cause problems if you power them with the vehicle not in reverse. If in fact you are talking about having them also hooked up to backup lights.
Sent using smoke signals
14 Sport,
You are a genius! After way to many private messages, got it to work just fine!! I ended up mounting the light on the spare tire mount. I like the fact that it can throw all of the light in a flood pattern, and no one can get to the light. Ran the power wire, following the factory wiring, then out, down through the rear tail light compartment, and inside the frame rail to the relay(s), mounted on a bracket in the engine bay. My only regret is that the rugged ridge apillar mount, doesn't fit quite right. I had to use a heat gun, and bend it to fit right.
thanks again 14 sport, and if I ever learn how to post pictures on here, from my phone....ya, that's an empty promise
dewey7015
dewey7015
14 Sport,
dewey7015
dewey7015
Congrats on your successful install! Last edited by 14Sport; Jun 1, 2015 at 07:28 AM.
the light works...magic!!
so, i ended up pulling all wires from the relays, and wired it just like the schematic....does that mean i wired "the negative side of the switch" ? I meant to ask you. i reviewed your previous posts on relating to the schematic, and in one you wrote " and you could also wire this to the negative side of the switch"....so i thought your schematic had me wiring the switch on the "positive" side.....electricity is fascinating, but baffles me...'
When the positive side is switched, you're basically just cutting the positive wire and inserting a switch. So you have 12V going to one side of the switch and the other side of the switch connected to the relay coil, either pin 85 or 86. It doesn't matter as long as the opposite side of the coil is run directly to ground.
When switching the negative side, you're cutting the negative wire and inserting the switch. So a wire is run from the switch to ground. The other side of the switch then is connected to the relay control circuit, either pin again will work. The remaining control circuit pin on the relay then needs to be connected to 12v instead of ground, the opposite of positive switching.
Do you understand the difference or should I try to explain it better?
that is the best explanation yet. the moral of the story is, that there is nothing equal to experience. i still only have one wire coming from the relay, mounted under the hood, to the switch. i spliced a dimmer wire, and a power when the key switch is on, into the switch. it works. jeep hasnt burned....yet. it won't..all wires are taped, inside loom, even inside the frame rail..lol
seriously, thank you.
