switched power source
I'm wiring up my everblades heated windshield wipers and was looking for a power source. Is the switched accessory plug wiring capable of supplying a steady 3-6 amp draw? if not, where is a good switched source near the driver?
The three accessory sockets are fused for 20 amps.
Here is a thread showing how to get switched power without tapping the wires to one of the outlets.
https://www.jk-forum.com/forums/jk-e...source-191552/
Thanks, Ron. I see how that works. Pretty slick. But for this particular use, I've already got the switch inside the Jeep behind the dash, so I think I'll just tap the wire to the switched ACC outlet in the dash. Now that I know that's rated for 20amps, and my load is 3-6 with a 10amp in line fuse, I know I'll be fine. I didn't want to overload that circuit.
Thanks again for the quick reply.
Most people do prefer to tap the wire to the outlet. I've never been a fan of that, and went to this much effort to avoid it:
https://www.jk-forum.com/forums/jk-e...source-189556/
