Tap light in sound bar on 4 door
Ok,
I am assuming (big one here) that the sound bar in the 4-door and 2-door are the same... if so the touch light from the back should fit in the sound bar... correct? I'd love to be able to turn on the dome light without cranking the dash lights and MyGig... worth picking up a rear touch light if it will work... Any feed back... someone who has access to both a 2 and 4 door take a look for me...
Thanks!
Thanks!
Part #?
I think I may give this a wirl... any of you guys happen to know the part number for the rear tap light and I'll get one on order. How hard can it be, right?
Ok, I took a look without pulling the sound bar a part and it looks like the bezels on the rear and sound bar light are the same - I *think* the rear light can be moved to the front and wired up to work... I think.
I took both of mine out and they have the same part #s stamped on them. The only difference I could see was the switch part. The plug is the same, just missing one of the wires. The local Jeep dealer wants $71 for the switched light and said he could'nt get me the wire terminal, just the whole harness. I looked at Napa and on the web a little with no luck on the terminal yet. Anyone know where to get chrysler terminals?
