There's a lot that I don't understand about lighting...help
Here I am trying to narrow a cloudy vision in my mind about what the outcome of my lighting project should look like. It seems there's one of every shape, size, and bulb type out there. Lots of cool stuff.
I think I'd like to go with 2 windshield pillar mounted lights, and a flood for the mast on the rear tire carrier. It almost feels like I'm under-building my setup. Here are some questions:
1. LED vs conventional/halogen: I know a LED bulb itself uses very little power, but in an automotive setup I know resistors are used for various reasons. In the end, does a LED lamp assembly (with resistor) use less power than a regular halogen lamp assembly--assuming they're the same size, just different type bulbs?
2. With the factory headlights and driving/fog lights on, and two windshield-pillar lights running, am I at risk of pulling too much current at idle? What about if I added two more lights on the front bumper? I know there has to be a point at which the draw is too much for the alternator to keep up with. Does the Jeep's computer have a fast-idle setting that will kick in?
3. Are windshield pillar lights legal for on-road use? My gut feeling is NO. If you've been caught, what's the typical penalty? Equipment violation?
What are the top brands these days, and who makes really high quality stuff?
What are the top brands these days, and who makes really high quality stuff? .
I appreciate the reply. In theory I should have the 140amp alternator but even then it doesn't sound like running 2 additional lights would be a concern.
I've been looking around....does anyone make a wiring kit for aux lights, in general? I want to do an a-pillar switch setup and wire up everything right with fuses, relays, etc, with the interest of maybe adding more lights later, or other accessories.
