Tip: myGIG RER & REW Bluetooth Activation
Just wanted to share my experience with my myGIG which had uConnect and Bluetooth disabled.
I was helped via http://mofv.com/MyGIG/BBS/viewtopic.php?f=4&t=157 (credit to mr. CD1) and was able to activate this functionality by upgrading the software which can be downloaded via the same site and then through the ENGINEERING MENU of the myGIG:
a) Press and hold the MENU + Seek up + Seek down buttons
b) Then, press the soft arrow button on the screen until you are at the last menu page.
c) Then, press the menu item to "Enable JK HFC/VR module" (or similar). Be sure to confirm, if needed.
Bluetooth worked like a charm and I could pair instantly ... now waiting for the mopar uconnect microphone to be shipped!
Last edited by Robar; Jul 17, 2008 at 02:42 PM. Reason: PLEASE DON'T POST DIRECT NON SPONSOR LINKS.
Yeah I have had mine in for two weeks and It has been great! It is funny how everyone said the Jk was not supposed to get the Uconnect, and the part # for the microphone does not list it as being supported. Then you just tell the dealer to order the dang thing, and when you get it and read the instuctions from mopar/chrysler the last few pages are on how and where they believe the best mounting location for the microphone is, freking nuts. I just use mine for phone use and that is what I wanted out of it, having to touch the uconnect on the radio to then tell it what to do is retarted, may as well just push the button.
If your phone is paired with the unit, and you dial by hand from the phone, it uses the mic and speakers, etc. so basically you would be using just like a bluetooth headset.
I like to use the voice commands.
push 1 button, say call "wife, work, whoever" and the type of # home, work, mobile and it confirms it and then you say yes and there it goes.
Or you can just press the button and say dial and the give the # and it enters it in for you.
I have had problems with xferring calls in progress using the UConnect and Bluetooth when I exit the Jeep -- I posted a new thread on the subject but thought I would ask --- how does this work for you ?
You can also use the VR command "transfer call" before you exit the Jeep - if I recall correctly.
Followed the steps and voila, worked like a charm. Paired my Motorola phone w/out an issue. I just need to now wait for the microphone.
I can not thank the members here for their great posts. Some of the service personnel at the Chrysler Dealership did n't even have a clue on this engineering menu. Thank you all.
