Uconnect HELP
Old Oct 15, 2013 | 01:02 PM
deepjeep13's Avatar
Default Uconnect HELP
Hey folks, so when i bought u saraha i didnt have you connect but i have the chance to buy everything with steering wheel controls. My question is can i plug it all in and use it?
Old Oct 16, 2013 | 04:51 AM
xsdbs's Avatar
1) What radio do you have?
2) Does the radio have the Uconnect buttons?
3) What all is included in the kit that you're looking at?
4) Depending on the radio, after the install you'll need to get the vehicle flashed for sales code RSP.
Old Oct 16, 2013 | 08:56 AM
deepjeep13's Avatar
Originally Posted by xsdbs
1) What radio do you have? 2) Does the radio have the Uconnect buttons? 3) What all is included in the kit that you're looking at? 4) Depending on the radio, after the install you'll need to get the vehicle flashed for sales code RSP.
I have the screen unit with buttons
Old Oct 16, 2013 | 01:16 PM
jwilson2598's Avatar
Which screen unit? In the lower right corner of the radio there should be a 3 letter code that will tell which model it is.
Old Oct 17, 2013 | 05:58 AM
xsdbs's Avatar
do you have a picture of the components that will be included in this kit that you mentioned?
Old Oct 17, 2013 | 12:59 PM
deepjeep13's Avatar
The numbers are RH8 and i dont have pictures all the components are still in the jeep being parted out
Old Oct 17, 2013 | 05:26 PM
That is actually a B, so RHB. need to verify the components as xsdbs mentioned.
Old Oct 23, 2013 | 03:41 AM
xsdbs's Avatar
You'll want to make sure that you get the:
1) radio
2) Uconnect main module
3) mic from the drivers "A" pillar and the lead cable from the module to the mic
4) Integrating harness pigtail between the radio and the Uconnect module
5 Sat radio ant and lead cable that goes to the radio
6) steering wheel control plate
Then remember that after you install everything that you'll need to go to the dealer and have the vehicle programmed for sales code "RSP".
