VIAIR OnBoard Air Systems
Old Apr 22, 2011 | 08:03 AM
Viair's Avatar
Sponsoring Manufacturer
VIAIR Representative
Default VIAIR OnBoard Air Systems
http://www.youtube.com/watch?v=Y6jK-ldMk6s
Old Apr 22, 2011 | 09:52 AM
will16's Avatar
Cool. So the heavy duty system can operate an impact gun for long enough to do a tire rotation?
Old Apr 22, 2011 | 10:44 AM
CrazyCasey's Avatar
It might.... I have single compressor with 2.5 gallon tank and I love it. Airs up my 37s from 10 psi to 35psi in about 15 minuites. If I did it again I would do dual compressors and hopefully cut that time to 10 minuites or so
Old Apr 22, 2011 | 11:01 AM
Viair's Avatar
yes,
a 10005 Heavy Duty OBA will pull off roughly about 6-8 lugs when plumbed correctly.
Old Apr 22, 2011 | 11:09 AM
ronjenx's Avatar
VIAIR Rep,
What is the difference between a VIAIR compressor that has a defined duty cycle, and one that is rated to run constantly? (100% being up to an hour)
Is it the head design, piston seal material, motor windings?
Can you give a little detail about it?
Old Apr 22, 2011 | 12:57 PM
Viair's Avatar
Originally Posted by ronjenx
VIAIR Rep,
Well,
A good way to explain it is:
33% duty cycle is like a Track Sprinter
100% duty cycle is like a Marathon Runner
the track sprinter is going to run alot faster but can only run for so long before needing a rest.
the marathon runner will be slower but will run for a much longer time.
theres no difference in the way the compressors are built besides bore size, stroke, & motor RPM
Thank you,
Landon List
Business Development Specialist
VIAIR Corporation
t: 949-585-0011 x114
f: 949-585-0188
e: landonl@viaircorp.com
w: www.viaircorp.com
Old Apr 22, 2011 | 01:01 PM
robsjeep9's Avatar
JK-Forum Ambassador
So the Viair 4300 is it a sprinter or marathoner??
Old Apr 22, 2011 | 01:04 PM
ronjenx's Avatar
VIAIR Rep,
Originally Posted by Viair
Well,
Thank you,
Landon List
VIAIR Corporation
f: 949-585-0188
Well, I was wanting to know if there are any physical/mechanical differences in the compressors.
It looks like you are saying there is no difference; just that one has a higher rpm than the other. Correct?
RPMs would be governed by motor windings?
Old Apr 22, 2011 | 01:11 PM
Viair's Avatar
the 400 series would be a sprinter
the 400 series comes in these variations
p/n 40040
p/n 40013
p/n 1005
p/n 40043
p/n 40045
p/n 40047
Old Apr 22, 2011 | 01:13 PM
Viair's Avatar
you are correct on all counts, but also bore & stroke.
