What is the "ET" value in the Speedometer Display?
Old Jul 12, 2011 | 03:19 PM
jhol111964's Avatar
Default What is the "ET" value in the Speedometer Display?
I looked around and couldn't find an answer. When I toggle thru the "Step" button menu on my steering wheel, I understand the avg mpg, outside temp, direction, but there's a "ET" display that's around "38:35" for me. Is this engine hours or something?
Old Jul 12, 2011 | 04:05 PM
weebus's Avatar
Default et
i think its elapsed time it can be reset to o it will keep track of time of a trip if you reset it before you start out
Old Jul 12, 2011 | 04:20 PM
86CJ-07RUBI's Avatar
It works great as a lap timer at the speedway when racing
Old Jul 12, 2011 | 04:33 PM
TURTLECON's Avatar
It's Elapsed Time. However it only works if your Jeep is on. It stops when you remove the ignition key, so it's not like a stopwatch/clock timer that might keep counting when it's off or in "sleep mode", if that makes sense.
Old Jul 13, 2011 | 09:30 AM
jhol111964's Avatar
Thanks a bunch -jim
Old Apr 25, 2012 | 04:59 AM
Mikedag's Avatar
So how do you reset it?
Old Apr 25, 2012 | 05:52 AM
tomb's Avatar
Press and hold.
*edit* Press and hold the reset/selector button that is.
