where do I run a AMP power wire through firewall
I have been looking all over my jeep to find a good spot to run the power wire to my amp. Does anyone have a picture for me?
Also open either door. On either side of the dash remove the plastic end panel. If you look forward through there you will see yellow expansion foam. Poke through that and you're under the hood. Kinda. Closer to under the cowl.
https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/best-place-run-wires-cab-77168/
This is what Red Rock is talking about. Pic near the bottom of the page.
