where to put the lockpick
Behind glove compartment for right side (remove door to expose space and see path to center console) or below steering column for left side (remove lower panel to expose space). There's also a penetration on both the very top right and left corners of the firewall to get cables out to your cameras. It's filled with rubber grommet - just poke a hole through it. This is on a 2010 - might work for a 12...
thanks MoveRight and texascodmw3 Ill try that this weekend.
invzibl
So is the lockpick worth it? Which one did you guys get?
I got the v5 and I think its worth it for the ipod intergration and cameras. also you can mess around with it while your driving. I hope this helps.
invzibl
The wiring harness is plenty long to hide it in several places. I tried several places, but under the glovebox seemed to be the best place.
I ran the wires from the back of the radio to right and under the glove box.
Right now, the lockpick unit is just sitting down there, but you can zip tie it to the metal crossmember there. I have head module for my Cobra 75 zip tied to it right now though.
