Windshield lights where to mount the switch
Old Nov 14, 2010 | 07:48 AM
  #21
Blksilverado's Avatar
I got my switched power for my switch from the back of the power outlet on the dash. If you want constant power go to the battery...
Old Nov 14, 2010 | 08:07 AM
  #22
Mariner's Avatar
Thanks for all the options every one, my new lights didn't arrive on Friday so I've got another week to plan this out. Hopefully next weekend i'll get er done.
Old Nov 14, 2010 | 08:18 AM
  #23
Highlander's Avatar
Originally Posted by JaxLoki
I'm not quite the expert with wiring. I have a relay wire (blue) going to the switch in the dash, then a black (ground) to the footwell from the switch. Now I need to find a wire to splice into that is constant for the led light on the switch. There are three posts on the switch. If I run that third wire back to the battery won't the little led light always be on and drain the battery? Sorry for the elementary questions, I just don't want to jack anything up.
I think it will only be on when the switch is on, right?
Old Nov 14, 2010 | 09:47 AM
  #24
pontiacstogo's Avatar
I was really reluctant to drill a hole in the dash to the left of the steering column, even though that seems a pretty convenient place to put a switch. I ended up pulling the drivers side A pillar cover and there is a ton of room behind there. Routed the wires through the firewall hole on the drivers side and straight up behind the pillar (sorry for the crappy pic);
The only concern I have with this location is the LED light on the switch - it might be a distraction while I'm driving - I've run my driving lights off the high-beam wire so the blue LED will flash on and off with the high beams. If I end up finding it annoying, I'll disconnect it.
And to answer the previous poster, the led light on a lighted switch should only be on when power is passing through the switch.
