windshield wipers won't shut off....
So we go to leave this morning, and wipers are going nonstop. Lever dpesnt do anything.
I pull the fuse out so they stop.
Now turn signals don't work and headlights stay on when the jeep is on. No high beams either.
Anyone have something like thish happen?
You can disconnect your neg. battery terminal, then go inside the jeep and step on the brake to reset your computer. let your jeep sit for 5-10 minutes, and hook the cable back up. See if that helps.... any codes pop up?
The following 3 users liked this post by rmjeepthing:
The following 2 users liked this post by El Duderino:
Big Bushwick (10-19-2023),
tkbales (07-19-2020)
Windshield wipers won't turn off
Thank-you guys for your info ... Had the same problem (08-10-15) and was going out to disconnect the neg terminal, but tried one more thing ... The turn signals would not work (as stated) so I checked my lights and turned them on and off ... Something reset (?) and then everything worked fine ... Thanks for the heads up ... trihiker
mikhull (08-03-2018)
Same here, just happened to me last week after having left the battery disconnected for 2 weeks when on vacation. Flipped the lights off and on and it magically fixed it. Wacky shit.
Wow, saved $$ by following this, local dealer gave me a quote of $1000. To fix my wife's wipers that wouldn't turn off then blinkers wouldn't work. I read this post and 30 minutes later everything works. Thanks to all that posted
Windshield wipers wouldn't shut off
You ROCK!!!
Thanks
Missy from SugarLand Texas 😎
Robert Breckner (04-06-2020)
'11 jp liberty, wipers won't stop, signals won't work
By disconnecting negative battery terminal for 20 min. and stepping on brake, wipers and signals returned to normal function. Thanks to all who recommended this, saved a lot of time and $.
