Wire for instrument panel lights?
Old Nov 13, 2008 | 07:40 PM
SpinningBull's Avatar
Question Wire for instrument panel lights?
Has anyone found a way to tap into the hot wire for the instrument panel lights without removing the dash? I got a lighted clinometer off ebay for $1.99, and I'd love to wire it into the dash's panel lights. The service manual was virtually no help finding where to tap in.
Anyone tried this?
Old Nov 14, 2008 | 06:31 AM
KMB-JK's Avatar
Check this out, I did this to cast some light on the cupholder area. The process is the same, and it is on the dimmer.
https://www.jk-forum.com/forums/show...t=40202&page=2
Old Nov 21, 2008 | 10:27 AM
Default Thanks!
Got it, thanks. Does that bundle come out on the driverside under the dash?
Old Nov 21, 2008 | 10:33 AM
stfuz's Avatar
Nope. Just finished lighting up my Dark space like this thread...
https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/big-dark-hole-night-28795/
and I tapped into the Orange with Grey wire for hot and the Black one for ground. It was a tight space. too tight for my bulky hands. All 4 of my lights dim and I can't wait till tonight so I can see what it looks like.
Good luck. It took me about an hour and a half to complete it.
Fuz
Old May 24, 2011 | 01:04 AM
Charlie Mike's Avatar
I have a 2011 Wrangler. I want to do the same thing with this illuminated rocker switch...
So when the dashboard lights turn on automatically, the light inside the rocker switch comes on simultaneously with the dashboard lights. Does anyone know if the Orange with Grey stripe (from this thread) will be the same wire to tap into for the dashboard lights with the 2011 Wranglers???
Old May 24, 2011 | 03:41 AM
JK-Ford's Avatar
Sorry man. I don't think that you can make that switch work that way. The lamp in the switch is wired internaly so that it recieves power from the switch power source when the switch is turned on.
Old May 24, 2011 | 10:28 AM
Actually I think this particular switch has a separate circuit that's independent of that. Here's the circuit diagram:
Here's the website where I'm buying it from:
http://www.otrattw.com/proddetail.ph...F76B-AYCBL-RK1
Anyone know what wire I could tap into to have the switch's internal lamp turn on simultaneously with the dashboard lights??? (I have a 2011 Wrangler)
Old Aug 23, 2016 | 04:26 PM
newbluesparky's Avatar
this might be the wrong thread and I tried to delete but couldn't figure out how but I was just checking to see if anybody figured out a dash light kill switch yet?
