2015 JKUR-HR Build Thread - Bright White - Mudmutt
Was able to find a dealer who is "mod friendly" and get the head unit config changed (Diehl in the Pittsburgh area). Based on the Jeeps in the lot and how easy they were to deal with, I think that I'll use them for any other services I need that I have to have done by the dealership.
The picture is pretty good, I moved the camera down just a bit from that angle, but overall I'm happy.
The one thing I noted that's different than cars I've had with this as a factory option... Because the camera power is from the reverse light, at the instant you move out of reverse, the camera shuts off. In other vehicles, it seems to have a 5-10 second delay before shutting off. I'm not an expert with electrical work, but if I can find some type of capacitor that would help maintain the 12v for 5-10 seconds, it may be a nice mod to make to this setup.
Was there any reason that your spare wouldn't fit with the stock carrier(aside from the added weight and stress on the spot welds)? I have a 2015 JKUR Hard Rock as well and was able to fit a 35" BFG KO2 with stock wheel on the tire carrier without a spacer or anything except for cutting down the CHMSL and having it shine through the spokes on the wheel.
Anywho, Jeep looks nice!!
Two observations after living with this for a couple of weeks.
1.) The guidelines are obviously a "one size fits all" design for this camera. I've backed up to where a wall is all the way at the end of the guides, well into the Red, and found that I"m still 8-12 inches away from the wall. So I just adjust.
2.) Because the camera is attached to the back up light, it's only powered while the Jeep in IN reverse. As soon as I take it out, the camera turns off. On other vehicles I'm used to there bing a 5-6 second delay (I think I mentioned this earlier). Since then I've fumbled around the radio settings a bit and there was a new option added to the radio setup when they enabled the rearview camera. It appears to be the setting to set the radio for that delay. I've turned it on and the screen looks like the radio is continuing to "see" the camera for a few seconds after I remove from reverse, however the camera doesn't have power so it's just a black screen with an X then. So I still need to solve the issue of a power capacitor or something to help keep it on for just a bit longer.
But simple answer, yes, I'm happy with it. I guess I could have started with that...
Are you planning to stay with this configuration long term? Do you have pictures of how you trimmed the CHMSL?
Without modifying the CHMSL, certainly the lugs wouldn't reach the spare tire with the added width. Since I already knew I didn't want the weight on my tailgate, I guess I didn't pursue trying to make that work any further. I knew I could have also used another wheel spacer and that would have accomplished the same thing, but I didn't want to invest into something I knew wasn't my long term plan. Good to know it CAN fit with some trimming (which sounds like everything with a Jeep...).
One day, I'll buy an aftermarket tire carrier. For now, it seems to be holding up fine although I only have 700 miles of regular driving with it on the back. I just hope that I buy a carrier before any damage happens to the tailgate. Since its touching the factory bumpstops and the bumper, I don't think I'll have to worry about vibration tearing it apart. Just hope the extra 18lbs of tire doesnt kill it!
Here's a link to the mod: https://www.jk-forum.com/forums/jk-w...sl-mod-9352/#b
Nice thread and install, can you send me the link of the actual camera the you bought off Amazon. I just want to make sure the one I get will definitely work. I also just picked up my Rubicon Hard Rock edition and wanted to add a back up camera.
