Ade's JK Build (2 Door)
Old Feb 16, 2015 | 08:36 PM
  #81
BubbaJK2012's Avatar
Originally Posted by ade
Thanks, we will have to hit the trails soon. Have you installed your sleeves yet, I have a set to install also.
Sleeves, guessets, Reid knuckles, pro steers, RCV axles, big brake kit, Currie Drag link and steering
Old Feb 16, 2015 | 08:38 PM
  #82
Thanks Bubba. Do you have a build thread for your 2 door?
I did mine back in 2010/2011 and was in the spring so I was in a hurry to get bubba on the road because I don't drive him on salty Minnesota roads
Old Feb 16, 2015 | 08:39 PM
  #83
I really like them. I wish the rears had some adjustment on height though, my 3" of lift only just clears them. Thinking of pulling one apart to see if I can shorten them an inch.
I currently run the speed bumps front and rear and run great as DD and running fast on back basic country roads
Old Feb 21, 2015 | 06:46 PM
  #84
ade's Avatar
ade
Time to keep everything safe under the hood. Installed a Mopar hood lock. 15mins work may save $100s, will never know but time to be safe.
Old Feb 21, 2015 | 06:51 PM
  #85
ade's Avatar
ade
So the Genesis dual battery kit went in today. Looked like it might be complicated but was quite simple in the end. Only needed to cut one evap tube, other seems to be ok in the new position.
Old Feb 21, 2015 | 06:56 PM
  #86
ade's Avatar
ade
Also installed the Genesis indicator switch unit. Install needs cleaning up a bit. Switch not sitting straight at the moment.
Old Feb 21, 2015 | 07:03 PM
  #87
JK505's Avatar
Also installed the Genesis indicator switch unit. Install needs cleaning up a bit. Switch not sitting straight at the moment. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=598118"/>
What's this switch for?
Old Feb 22, 2015 | 07:41 AM
  #88
ade's Avatar
ade
It allows you to check battery voltages and operate the boost mode. Bit expensive for what it does but went with it anyway.
Old Feb 24, 2015 | 07:44 PM
  #89
DJ1's Avatar
DJ1
Former Member
I have the Evo ones so I think it will be more as case of lots of welding than hammering into place. Will let you know when before I start, an extra set of hands is alway helpful.
Sounds good
Old Mar 23, 2015 | 11:57 AM
  #90
ade's Avatar
ade
Swapped out the rear CA skids for the EVO weld on ones.
Also started work on installing Teraflex prerunner bumpstops in the rear.
