GR8WHITE 2.0 (But Actually Silver) (40’s, 8 lugs, stretched)
Old May 24, 2016 | 05:11 PM
  #41
GreatWhite JK's Avatar
All Eastern Gear Supply stuff showed up today
Old Jun 1, 2016 | 04:25 AM
  #42
Started cleaning up the 60 and 14 bolt. Front is done but the back still needs a lot of grinding and one more leaf purch cut off. My order from TMR also showed up yesterday.
ID:	648516   Click image for larger version
ID:	648517   Click image for larger version
Old Jun 1, 2016 | 05:49 AM
  #43
Maertz's Avatar
Maybe im having a blonde moment but is that front passenger side drop?
Edit: nvm must be upside down hahah carry on.
Old Jun 4, 2016 | 07:08 PM
  #44
Got some work done today. Finished grinding the 14 bolt smooth and then i sand blasted the chunk with my at home pos sand blaster. Then burned the truss on.
ID:	648824   Click image for larger version
ID:	648825   Click image for larger version
ID:	648826   Click image for larger version
ID:	648827   Click image for larger version
ID:	648830   Click image for larger version
ID:	648831   Click image for larger version
Old Jun 11, 2016 | 04:25 PM
  #45
One pig piece of the puzzle showed up the other day
Old Jun 11, 2016 | 10:43 PM
  #46
TheDirtman's Avatar
What travel did you settle on?
There is a build going on with 16" ORi's on JKownerns right now as well
Old Jun 12, 2016 | 04:01 AM
  #47
Chuck-The-Ripper's Avatar
What made you choose not to weld to the center section?
Old Jun 12, 2016 | 05:48 AM
  #48
Originally Posted by TheDirtman
What travel did you settle on? There is a build going on with 16" ORi's on JKownerns right now as well
14" in the front and 16" in the rear
Old Jun 12, 2016 | 05:51 AM
  #49
On the artec full width trusses you physically can't weld it to the cast because it is gapped off the top of the pumpkin. Its that way so u can tilt the truss depending on your pinion angle.
Old Jun 12, 2016 | 06:10 AM
  #50
TheDirtman's Avatar
Welding steel to the casting takes some specialized welding as well. You can't just MIG it as it will only crack along the weld. It can be done but not by the average hobby welder.
