Please help!!!!
Old Aug 21, 2019 | 09:17 AM
_Brittany_'s Avatar
Update: I went ahead and took apart the engine.. I found pistons 1, 2, and 6 were basically destroyed.. I got new pistons.. rehoned the cylinder walls.. put it all back together and still had the crank no start.. so than I called a friend over to help me and i guess the guy who took apart my fuse box when I was replacing the spark plugs never hooked my fuse box back together all the way.. because I didnt realize that until way later I had already taken apart the pcm.. very bad idea yes i know.. so now i have it sent out to be repaired.. fingers crossed when it comes back next week itll all be working again! Thanks to everyone for all ur suggestions!! I greatly appreciate it all!!!
Old Aug 21, 2019 | 01:30 PM
Dinky Dau's Avatar
Veteran: Coast Guard
Great, wish only the best for you on the outcome! Young Lady, you are lucky to have a friend with the knowledge to help you in you endeavor!
Old Sep 7, 2019 | 01:38 PM
_Brittany_'s Avatar
Thank you to everyone for your suggestions!! The engine is back together yahoo!! I'm not going to explain what I did because it's so embarrassing but I ended up needing a new pcm and now my check engine light is on and when the jeep idles at a stop light the electronic throttle control flashes, traction light comes on, and than the car dies.. I'm not sure what to do.. I took it to o reilys they read the codes and i had 9 codes.. now i hooked it up to a little hand scanner and i have 1 code a p0507.. any suggestions?!
