after wheeling???
i was wondering what maintenance people do after they take there jeep wheeling? or what are just somethings to look for after you get off the trails????
It depends on where I've been wheeling----how off road so to speak...
At the trail: Air back in tires, check for anything loose, inspect for bolts, nuts that have come out of place, check for any parts that are missing (lost a steering stabilizer once--don't know where it went). If it was a rough trail (extreme type) then I will check welds too (I broke the track bar mount once).
On the drive back home: Steering, any pulling flightiness etc. BAS, etc lights come on, and steering wheel is off center---then adjust the drag link to put it back to center. Check to see that tie rod isn't bent.
The next day, I will look under the hood and under the jeep for fluids
I'll take it in to have it aligned, and check out if I have really beat it up.
I'll take it in to have it aligned, and check out everything at the shop if I have really beat it up.
Besides putting air back in the tires, I do an oil check and look underneath for anything our of sorts.
Then if there was any mud involved I look for a car wash to get the crud away from the wheels and brakes.
Then usually we all stop for a
![beer](https://www.jk-forum.com/forums/images/smilies/beermug.gif)
I'll crawl underneath and check the areas that may have scrapped. I look for fresh leaks as well as lose or missing nuts and bolts. I try and inspect once before I clean the underside ( cause its easier to see what scrapped) and more throughly after I pressure wash the underside.
Tom
Tom
![rotflmao](https://www.jk-forum.com/forums/images/smilies/yelrotflmao.gif)
I like to give my Jeep a wash and i like to go over bolts and hinges with grease or WD-40 just to displace any moisture or water that has accumulated. There's a lot of mud where i live so i like to clean it all out of the tight spaces, especially around my shocks and bumpers!, but like it was said before, it really depends on the type of wheeling you do.
After going in the mud pools. The engines all muddy, how do you guys take care of this? Take out battery and cover the alternator and give it a hard spray down?
Thanks,
Pluke -
Thanks,
Pluke -
