JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Best way to stretch a new winch
Old 06-29-2009, 04:19 AM
Finnster's Avatar
Default Best way to stretch a new winch
I have a new Warn winch. What is the best way to properly stretch the cable?
I have heard of ideas such as winching the Jeep while the parking brake is partially applied. Any other ideas? The manual says a 500 lb load should do it....how do I replicate this?
Old 06-29-2009, 04:33 AM
ytee's Avatar
I just hooked the winch line to my truck and pulled the Jeep to it with winch.
Chris
Old 06-29-2009, 04:55 AM
openloop's Avatar
nice post JKDoc.
thanks for the write up.
Old 06-29-2009, 05:09 AM
Wakeup!'s Avatar
Those who have bought syn line, what did you do with your metal cables? Did any of you keep them as winch line extenders?
Old 06-29-2009, 05:11 AM
09rubicon's Avatar
Originally Posted by JKDoc
Fully extend the cable and then remove. Replace with synthetic line. Wind back in under tension of pulling the Jeep up a slight slope. Best $100 upgrade you can make.
However, if that is not in the picture, fully extend the cable except for a few (5-6) wraps on the drum. While the cable is extended and not under a lot of tension, apply a light coating of light oil to the entire cable. Allow it to penetrate the cable. Then apply tension by pulling against the emergency brake or pulling up a slight grade. You should see oil squeezing out of the cable strands as tension is applied. This lubricates the individual strands and allows them to slide against each other protecting the small cable strands. Wipe off excess oil as it nears the fairlead. Wear gloves and be prepared to stop the winch if your glove or wrag snags a cable strand. The winch will easily pull your hand through the fairlead. Do the wiping far enough away from the fairlead that you can stop the winch before your hand gets there. Alternatively, forget the wiping as you reel in and wipe the excess from the winch plate and fairlead when you are done.
x2 I usually will use a telephone pole as an anchor and pull the vehicle towards it. If it is a level area apply the parking break partialy, if there is any incline that should be enough weight. That was a great comment on the oil above! Also take your time and ensure your cable is wound properly, no sense in ruining a new cable before you even get to use it.
Old 06-29-2009, 12:47 PM
Enteric's Avatar
If you have a sister in law, that is ~500lbs, you can just drag her up the drive. Mother-in-laws work well too.
Old 06-29-2009, 01:51 PM
Former Member
Bustabizz's Avatar
If I respool my cable, I usually hook it to the back of my truck and just winch up the driveway and help feed the cable as it goes in so it spools evenly.
Old 06-29-2009, 01:57 PM
nmwranglerx's Avatar
Where did you get synthetic line for $100? I was just quoted $315 for 100 ft. to replace winch cable on my XD9000
Old 06-29-2009, 02:04 PM
Finnster's Avatar
So let me get this right....... Oil up my sister-in-law and tie
her to a telephone pole....then put my mother-in-law under my
jeep to simulate a parking brake......winch both of them through
the fairlead, uninstall the cable and sink the evidence in a lake and
replace with a synthetic cable. Perfect!
BTW, what synthetic cable do you recommend? Are they all
pretty much the same?
Old 06-29-2009, 04:27 PM
jkman77's Avatar
I work with wire slings moving equipment every day. Jkdoc knows his stuff. Just rember to do that process every month or so depending on your weather conditions. Wire rope likes oil.
Quick Reply: Best way to stretch a new winch
