Can I do the jeep jamboree with a stock JK?
I did Mole Lake last year with my eldest son... Had a great time... My first off-road experience. Double check minimum equipment requirements with JJUSA just to be sure. I do recommend rock rails as I saw one stock JK rip off their side step.
You'll have a great time... I'll be back again this year with my other son. Hope to see you there!
I did Mole Lake last year with my eldest son... Had a great time... My first off-road experience. Double check minimum equipment requirements with JJUSA just to be sure. I do recommend rock rails as I saw one stock JK rip off their side step. You'll have a great time... I'll be back again this year with my other son. Hope to see you there!
Yes, even the owners manuals recommends taking them off beforehand. My buddy just busted his a few weeks back... You can now find them in the For Sale section here listed as best offer
Your Jeep? ...Your tires? That is your weak point. Your stock sport is running on P (for passenger) rated tires with weak sidewalls and shallow tread (as much as 5/32 depending on tire compared to) in comparison to a lugged LT (light Truck) off road tire, be it a mud terrain or an all terrain...
So yes I would say your fine, just get a good spotter and listen.
Buying tires for a jeep is a balancing act between good off-road performance and all of the other driving you do. I ran KM2s got almost a year and a half; a fantastic off road tire but for that other 90% of my driving maybe not the best pick. Right now I'm running Hankook MTs, still as great off road as the KM2s were and a little better on the highway but still not the ideal balance between both worlds (is there one?)
You're in the northern U.S. Your tire needs across that spectrum of off road and highway usage has a few more variables than my needs, snow for one. People in your neck of the woods rave about Goodyear Duratracs whereas down in my neck of the woods the same tire is disdained for its fragile sidewalls, frequently cut on sharp rocks. Different areas, different needs.
Find out what tire other Jeepers in your area recommend, not what the tire store guy is pushing on sale at the moment. My recommendation is that you look at light truck LT tires, not passenger P-Metric tires, as airing down and sharp objects are the death of P-Metrics. Next I'd recommend as open a tread pattern as you can get while balancing your on and off road driving needs.
The Goodyear duratrac or its sister tires the Kelly safari or Fierce attitude are good choice where you are at as a good all around tire. I would look into a set on 16" or 17" wheels if you are buying them for your off road adventure. It will give you more side wall flex for traction and the rubber cost less in smaller wheel sizes. I would stay away from E rated tires> C would be best. I have a buddy that runs the Cooper SST and they hook up well for traction at Badlands park there in Indiana.
