JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
d-rings & recovery strap
Old Jan 25, 2010 | 09:54 AM
smc's Avatar
smc
Default d-rings & recovery strap
In the past Ive always used a tow hook to loop my recovery strap onto when trying to retrieve a stuck vehicle. My new jeep has the mopar offroad bumper which includes a mounting point for d-rings which I plan to install soon.
So my question is, when using the d-rings for recovery... Do i unhook the d-rings from the bumper and put the strap in the d-ring then reattach to the bumper? Or is it ok to hook two d-rings together (one attached to the bumper and the other to the strap)?
Also is there an advantage to d-rings vs. a tow hook? I have the mopar offroad front bumper w/ front tow hooks mounted but was thinking about removing the crush cans and plastic caps so that i can use a d-ring mount there as well. Am I better off keeping the hooks? Or are the d-rings a better option than two hooks?
Old Jan 25, 2010 | 10:13 AM
interceptor_1972's Avatar
May not be the best person to answer this question, but the best of my understanding, everything I read about D-Rings mentioned to not hook 2 D-rings together. Your first statement would be right - unhook from the bumper, through the strap and attach it back to the bumper. If I'm wrong on this, I'm sure someone'll correct me
On the tow hook vs. D-Ring, if you were trying to pull someone out, you'd use the tow hook; if someone was pulling you out, they'd want to hook up to the D-Ring. Other than that, I'm sure you could use either.
Old Jan 25, 2010 | 10:54 AM
jeepmedic's Avatar
I have always used the strap directly to the D ring. Not doubling up the D rings...
The D ring will always be safe than a hook, as the strap / hook cannot slip out and snap back at you or your jeep. Closed ended recovery straps with D rings are always safest for that reason.
Old Jan 25, 2010 | 01:48 PM
you gotta un-hook the d-ring anyway so just use the one. i'm curious as to why 2 d-rings are bad. isn't it like two big chain links.
Old Jan 25, 2010 | 02:15 PM
GreytSilly's Avatar
D rings are constructed to pull in a direction perpendicular to the attaching pin. As soon as you start to pull at any angle off that axis, you start to lessen the safe load of the D ring. If you put two D rings together, you could possibly pull sideways on one of them, greatly diminishing the strength of the D ring.
Old Jan 25, 2010 | 02:32 PM
smc's Avatar
smc
I figured that was probably the way to go, just making sure.
Thanks for the info guys, much appreciated.
Old Jan 26, 2010 | 12:08 PM
dburgette's Avatar
The less metal you have attached to each other the better, for safety reasons. A tow hook will do the job, but it is nice to have a closed end to ensure no slippage.
Old Jan 26, 2010 | 12:58 PM
smc's Avatar
smc
Do you guys leave your d-rings attached all the time? Or do you just attach them when offroad then take them off during the rest of the time?
Old Jan 26, 2010 | 01:17 PM
dburgette's Avatar
All the time. I guess it might depend where you live.
Old Jan 26, 2010 | 03:30 PM
mainejeeper's Avatar
I like hooks for quick and easy cold weather recovery. I don't have to take the gloves off to hook up a strap! One big advantage to d-rings is that you can use them as jacking points with a hi-lift jack. Just flip them up, insert the jack foot and use it as a solid mounting surface. Todays bodies have so many angles it can be hard to find a secure place to jack from.
