Help with Warn Zeon 8000
First, I'd like to say, I've tried to perform a search for 2 days now. The website won't allow it. Some type of issue I guess.
I'm looking for a winch for my 2012 JKU automatic. Currently, I am running a "stock" system with stock tires. No lift at all. I am intending on ordering a front bumper soon. Possibly stepping up to 285/70/17 tires. I live in FL, and won't be rock crawling what so ever. It is just a desired accessory to have in case the mud gets too deep. I've been looking at the Zeon's. Please let me know if you feel these are nice winches that can be depended upon in the time of need. Also, is an 8000 pound version enough for my system? Thank you in advance.
Josh
Josh
Josh
Josh
Here is what you can expect with 285/70r17 a bumper + winch and no lift.
Then with 2.5" lift
Here is the write up I did on installing that bumper and winch.
https://www.jk-forum.com/forums/jk-w...nstall-292780/
Then with 2.5" lift
ESPI,
When you had it stock ride height, did you need any wheel spacers with the stock rims? Is yours an automatic 3.6? If so, what mileage are you getting now with your 2.5" lift and tires? What gears are you running?
If you are getting 285/70r17 you will want spacers. I went with after market wheels 17x8.5" with a 5.2" backspace to keep the tread just under the fenders. I have a 2013 auto with 3.73 and right now with winter gas I am getting 15mpg, but I tend to do 75-80mph on the highway. Over the weekend I was got 17MPG keeping it under 65mph. I have been tracking my MPG since I got it and the best I got stock was 19mpg. and the worst 14mpg. Right now the winter fuel does not help.
https://www.warn.com/truck/winches/ZEON_8.shtml
I was dead set on an 8k, but some of the trucks I go out with are much heavier than me at ~7500lbs and in order to get them out I had to use my snatch block and strap myself to a tree.
