JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Hi-Lift or Hi-Lift's FIRST RESPONDER ?
Old 09-27-2011, 04:27 AM
GJeep's Avatar
Default Hi-Lift or Hi-Lift's FIRST RESPONDER ?
Is the Hi-Lift's First Responder better than the regular Hi-Lift for wheeling ?
From what I read, the advantage for wheeling might be the rotating base -- with wooden blocks to sit on, it might allow better grip in some circumstances.
Comments? – From firefighters who have used it, maybe?
Thanks!
Old 09-27-2011, 05:19 AM
CottonFire's Avatar
Haha, never heard of it...we use hydraulic rams, but it sounds cool for wheeling. Any worries about it spinning off the rig tho?
Old 09-27-2011, 06:37 AM
D_engel's Avatar
i would be worried about it swiveling around while trying to use it on off camber situations. I would go with the original hi-lift.
Old 09-27-2011, 07:47 AM
GJeep's Avatar
Well, it doesn't spin freely of course.
It can be unlocked, rotated on it's base, then re-locked, before you use it.
The base can sit on longer wooden blocks.
Because it can be rotated, the blocks can be positioned either along the Jeep or perpendicular to it.
You can see it at - .....firstresponder.hi-lift.com
Old 09-27-2011, 08:21 AM
SiliconTi's Avatar
I like that base. Wonder if I can buy it separately. Also, I like the paint job - maybe I'll repaint my Extreme that way...
Old 09-27-2011, 08:45 AM
SiliconTi's Avatar
Lightbulb
Yikes! These jacks are $230 each for the 48". That seems unreasonable for just new paint and a base.
Old 09-27-2011, 11:05 AM
GJeep's Avatar
Yeah, expensive.
I think of bolting a plate under the Hi Lift's base – shaped so wooden blocks can be placed under it in two directions, either '–' or 'I'. At the same time, it may have pegs at the 4 corners, which stick in the ground.
Old 09-27-2011, 12:17 PM
GJeep's Avatar
So... has anyone here used the Hi-Lift First Responder ?
Old 06-21-2017, 06:07 PM
Kilted-jeeper's Avatar
My department has one, and I have used it. It has a lot of functions from vehicle stabilization to clamping and different attachment points to use for pulling from different angles. I am going to buy the conversion kit for my hi-lift.
Old 08-09-2017, 12:49 PM
eng23ine's Avatar
We have both versions.
Its the same exact jack, but the FR has an upgraded base and tip......not worth the price premium IMO.
Quick Reply: Hi-Lift or Hi-Lift's FIRST RESPONDER ?
