JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Issue on the beach today
Old 10-22-2010, 01:14 PM
db09JKU's Avatar
If I'm correct and the way I understand it, the transmission recall is just turning on the stupid light, it does nothing for the actual problem, it just lets you know when the problem happens. It's bullshit.
Old 10-22-2010, 01:28 PM
Smopho's Avatar
Did you turn off ESP? The traction control will sense wheel slip and kill power to the motor.
Old 10-22-2010, 01:29 PM
marshjo's Avatar
Do the 2011's have the trans overheating problem that you know of?
Old 10-22-2010, 01:35 PM
genesbro's Avatar
Originally Posted by Fluid72
Decided to cruise on the beach today. I put it in 4wd high and went. It seemed not to want to shift above 2nd or 3rd and the RPM's would just drop to almost a stall. I would need to completely let off the gas and press down quite a bit to get the RPM's back up.
Any ideas?
Should have been in 4lo and aired down, sand is hard on engine and tranny if you are not in 4lo
Old 10-23-2010, 01:29 AM
Skoalman's Avatar
My thought exactly. Turn that stupid ESP off and you should not have any problems.
Old 10-24-2010, 01:52 PM
Fluid72's Avatar
Thanks for all the info. went fishing today with 4wd low reduced tires to 18psi worked perfect!!! Didn't catch anything but .... my dog, some music and a nice day.
ID:	97734Click image for larger version
Old 10-25-2010, 04:40 PM
JKlad's Avatar
Yeah, the first time I hit the beach I had similar issues regarding falling RPMs; then I read about turning the ESP off (the 5-second press) & all good. Also with soft sand the extra rolling resistance demands a lot more power from the motor so I could see why yours didn't want to shift up. Though mines a 6-speed I often have to shift down to 2nd in the soft dry stuff & get the RPMs up high to keep going at a steady 30MPH; shift to 3rd, RPMs drop out of the V6s power band, and you lose power and forward momentum almost immediately.
Depending on how much beach driving you do it may also be worth having a look at an auxiliary cooler for your power steering fluid. There was a discussion somewhere else here on this forum about power steering pumps frequently failing after prolonged beach driving. It was suggested that the extra stress (and accompanying heat) caused by sand driving (not so much driving on the flat, hard sand by the waterline on the beach but in the rutted, soft stuff where your steering is constantly fighting the ruts and undulations) was killing the internal seals and leading to pump failure.
Old 11-04-2010, 06:56 AM
adrom's Avatar
ive had similar problems in sand. turning off the esp fixed it
Old 11-04-2010, 07:03 AM
johnr41a's Avatar
I wish I had a beach that I could complain about driving on....
Old 11-04-2010, 07:22 AM
JK Mikey's Avatar
Originally Posted by Locko
for what years ??
I have an 2009 and just had the recall work done yesterday. Im pretty sure 2010 and up already comes with the updates.
Quick Reply: Issue on the beach today
