JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
need help diagnosing winch problem please
Old Jul 23, 2011 | 04:08 PM
JEP THNG's Avatar
Default need help diagnosing winch problem please
Ok, to start with the embarrassing facts. 1. I installed a Warn M 8000 about a year ago. I have not used it yet 2. When I first installed it, I think that I flipped the cover over to make the wires easier to deal with. ?? 3. Since day one, it has had issues when i was trying to use it to attach the hook to the d ring.
It sort of was like it had a short of some sort. I had to insert the controller over and over to try to get it to work. I recently had to take it off and am unable to get it to work. I know this is a tough one, but i need to know where to start . Should I take the solenoid off and look for obvious loose connections? That would be logical. What next if I don't see any?
Suggestions appreciated. I will be working on this tomorrow. Thanks!
Old Jul 23, 2011 | 04:27 PM
Battlefrog's Avatar
Is it grounded correctly ?
Old Jul 23, 2011 | 04:29 PM
JEP THNG's Avatar
I am pretty sure it is. The ground is on the bottom of the winch correct? I ran that to the black terminal on the battery if I am not mistaken. I have not looked at it in a while...but that is what I remember.
Old Jul 23, 2011 | 04:36 PM
Battlefrog's Avatar
I know on my Xrc10 they are "letter labeled" a busy of mine had his reversed and would not wind back up. Have you tried re-wiring it and possibly grounding it to the frame?
Old Jul 23, 2011 | 04:40 PM
JEP THNG's Avatar
No, but I will try that. Thanks.
Old Jul 23, 2011 | 04:45 PM
Battlefrog's Avatar
I would also try googling the wiring diagram as well or trouble shooting techniques for that warn as well.
Old Jul 23, 2011 | 04:55 PM
20jk08's Avatar
Default Re:
Hope this helps a bit..
Note the ground ( small black wire) coming off the control box...
Also,,,I found the terminals which the controller plugs into on mine, had corroded and made a poor connection, I ended up hard wiring those..
Old Jul 24, 2011 | 08:49 AM
JEP THNG's Avatar
thanks for the diagram. I have mine wired this way, but I put the ground to the crossmember of the frame. Maybe i should try it this way.....
Old Jul 24, 2011 | 01:20 PM
JEP THNG's Avatar
the answer would be NO! it was attached to a painted surface....would this be the problem?
Old Jul 24, 2011 | 01:26 PM
just_jking's Avatar
Yeah need metal on metal
