off road tire pressures
I have recently bought a set of 17x9 pro comp rims and a set of 285/70/17 treadwright guard dogs. treadwright.com/p-52-285-70r17-guard-dog-m-t-d.aspx
There is a link where it lists most of the tire info. I'm trying to figure out what I need to set my staun deflators to with out being in risk of loosing a bead easily. I'm guess some where between 10-15 psi? any recommendations or tips on figuring out how low to drop them with out loosing a bead?
I agree here. I depends on the tire width/rim width proportion. The larger the proportion the lower you can go.
With a 12.50 tire and an 8" wide rim, it is fairly safe to be at 10, and even lower in teh 8 range. This depends on the tire brand as well. For example, I run both BFG Krawlers and Toyo M/T's in the rocks. The Krawlers will flex much better so they don't require the lower pressure to flex like Toyo's do.
It does depends on what you are doing. For most the trails I do here in Idaho I only go down to 20. When I go down to Moab I go down to 15 and don't air up until I leave.
It's easy to air down more on a trail if you need to, but it's more of a pain to air up on a trial, so I start at 15, and then drop it down more if I get to part of a trail where I need to air down more.
we do a lot of rocks, it's not moab but it is rocks, look up rausch creek. There is a fair amount of dirt trails and a little bit of mud. The tire link is up there so you can look at the tire specs too.
