JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
Offroading ????'s
Old Mar 24, 2011 | 09:49 AM
Mbosque09's Avatar
Default Offroading ????'s
So, I went to my first off road park in Bridgeport this past Sunday and everything went fine pretty much except for the end when my t-case lever went loose. But my main question, should I be in 4h mostly when doing trails or just put it in 4l and put it back in 2h when I'm back on the road leading in between trails? Cause Id rather not shift it too much and have another incident happen from whatever it was that broke. ( the crappy little plastic clip being my main suspect)
Old Mar 24, 2011 | 09:54 AM
tslewisz's Avatar
4 low whenever I'm trail riding.
Old Mar 24, 2011 | 11:05 AM
JKZinger's Avatar
If you run around in 4hi while on trails with hills you will eventually get your hot oil light to come on which is an overheated transmission if you have an auto. I use 4lo unless I need to go faster for some reason.
Old Mar 24, 2011 | 11:39 AM
Mbosque09's Avatar
Awesome, thanks for the feedback, what's the max speed I should go in 4L? I try not going over 10, input?
Old Mar 24, 2011 | 01:34 PM
Mbosque09's Avatar
Saw this on another thread : http://www.northridge4x4.com/proddet...prod=AA-715596 , worth the buy?
Old Mar 24, 2011 | 04:06 PM
rexicon's Avatar
yeah I've asked about that too but you can get the spare plastic clips that are the problem from the dealer for less than $1.00 a piece and carry a few spares
that being said I have yet to break one myself
Old Mar 25, 2011 | 03:37 AM
jpjunkie's Avatar
The part looks great but I've been shifting my JK in & out for 95000 miles now without any problems.
Old Mar 25, 2011 | 07:17 AM
Shankspony's Avatar
Exactly why I'm putting in a tranny cooler.
Old Mar 25, 2011 | 09:14 AM
Mbosque09's Avatar
That actually happened and I was kinda worried thinking,what the hell is a hot oil warning, so I shut off the jeep and let it sit
