JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
oil change 101
Old Mar 9, 2009 | 06:52 PM
  #21
JKJeeeep's Avatar
20 ft. lbs. on the old Oil Pan Drain-Plug. Found this on main page right here, Project JK what's new. ( Great write up!)
Another question needs asked, since the filter is vertical is there a flow back valve built in the filter. I thought I read that somewhere?
One thing I plan to do since I upped for the "Lifetime Warrenty",(bumper to bumper), is I plan on always buying my filter from the dealer. Heck that way I can show I'm changing the oil regularly and I have a paper trail from the dealer. ( Might be paraniod, just my idea.)
Old Mar 9, 2009 | 07:07 PM
  #22
Dizzyliz's Avatar
Thumbs up
Originally Posted by JKJeeeep
One thing I plan to do since I upped for the "Lifetime Warranty",(bumper to bumper), is I plan on always buying my filter from the dealer. Heck that way I can show I'm changing the oil regularly and I have a paper trail from the dealer. ( Might be paranoid, just my idea.)
I do the same
Old Mar 9, 2009 | 07:38 PM
  #23
berg's Avatar
The filter is horizontal. not vertical. It sticks straight out of the front of the engine, next to the pulley.
I keep hearing about a flowback/drainback valve in the filter. But I looked down the center hole of the Mopar filters that I use and don't see anything that looks like a valve.
I use the Mopar filter for two reasons. I was getting a knock on start with the Mobil1 fliter I used. It went away with Mopar.
And as you noted, there is a record of filters purchased from my local dealer.
Old Mar 9, 2009 | 08:47 PM
  #24
JKJeeeep's Avatar
Sorry I ment horizontal......Brain cramp i guess!
Your symptoms sounds like there could be a drain back in there some where? Anyone have more info on this?
Great site by the way.
You all Rock!!
Old Mar 26, 2009 | 09:29 AM
  #25
Donatello's Avatar
Originally Posted by kflash
I also pour oil into the new filter before installation. A neighbor told me he has never done this and has change his own oil his whole life. What is he doing to his motor by not doing this?
not a thing. my bmw 's oil filter housing was vertically mounted above the engine. I.E. no way to keep oil in it even if you wanted to pre-fill, and it wasn't a canned filter. Not to mention it was the biggest damn thing i've ever seen. almost 7qts for a 2.8L engine.
Old Mar 26, 2009 | 10:24 AM
  #26
db09JKU's Avatar
Great write up. Glad it is easy to get to everything.
Old Jun 14, 2009 | 10:36 AM
  #27
NIVA's Avatar
Did my oil change yesterday, poured 6 quarts of oil as specified by the manual, now the level is a bit higher then the safe zone, goes almost to the top of the "bent area" on the dip stick. Should I drain some oil?
Old Jun 14, 2009 | 12:04 PM
  #28
Chris333's Avatar
never heard of pouring oil in the filter before installation sounds like nonsence to me
Old Jun 14, 2009 | 12:28 PM
  #29
AZJeeper's Avatar
Community Favorite
Did you run the the engine before checking the level? By the time the oil gets into the nooks and crannies, it will go down a little.
I'm assuming you changed the filter. If you didn't, first off - shame on you! Secondly, it holds a fair amount of oil, so 6 quarts would indeed be too much.
Do NOT use less than the recommend amount.
Old Jun 14, 2009 | 12:47 PM
  #30
NIVA's Avatar
Yeah i changed the filter. I left the car overnight and checked the oil today to see if its different from what i saw yesterday after the oil change. I guess I will have to go get dirty and drain some oil.
