JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
oil change 101
Old Jun 14, 2009 | 12:57 PM
  #31
Muffins's Avatar
When I change mine it is usually just a tad high but after I'm done I take it around the block, check it again and it's good to go. I love how easy it is to do an oil change on the Jeep, heck, this vehicle is all around easy to work on
Old Jun 14, 2009 | 02:07 PM
  #32
zacjackson's Avatar
Thanks for the write up, I got my first change free from the dealer, but next weekend I will be due for number two. I think I will make the switch to synthetic.
Also, thanks for the idea of ordering filters through the dealer, how much do they charge.
I think my girlfriends Liberty is getting close to needing a change as well. maybe we can have an oil change party.
Old Jun 14, 2009 | 02:10 PM
  #33
08RUBIJK's Avatar
Originally Posted by NIVA
Did my oil change yesterday, poured 6 quarts of oil as specified by the manual, now the level is a bit higher then the safe zone, goes almost to the top of the "bent area" on the dip stick. Should I drain some oil?
This is why I don't pour in the full 6 quarts at first... I put in 5.5 quarts, start the engine and let it idle for 1 min. I then shut it down and let it sit for 10 minutes while I transfer the used oil to a container. I then add oil as needed to get the level to the top of the marker.
If my vehicle was overfilled, I would drain out a little oil: you should be OK leaving it though.
Also, after you change your own oil the first time, you should not need a filter wrench.
I also pre-fill my filter.
Old Jun 14, 2009 | 02:35 PM
  #34
AZJeeper's Avatar
Community Favorite
You need to account for the oil you use to pre-fill the filter. It's difficult since it's hard to keep some oil from spilling out when you go to put it on. However, you probably don't loose too much - just enough to make a second mess (1st is from when you took the old filter off).
Keeping it in the safe zone of the dip-stick is perfect. Check it after a couple of hundred miles (and about every 1000 as I do) and you'll figure out if you have enough. Checking it often is also a good way to early detect problems.
Old Jun 14, 2009 | 07:03 PM
  #35
NIVA's Avatar
OK, drained the oil, had to drain about half a quart. But now i have the peace of mind
Old Sep 28, 2009 | 10:42 AM
  #36
db09JKU's Avatar
Yay, my oil light came on, close to the second oil change, the first one I am doing myself!
Went to one of my Autozone's today, they didn't have 5w 20 in Mobil 1 Synthetic, they did in regular Mobil 1 5000 oil.
They did have 5W 30. Didn't buy any today. Going to check a larger store to see if they have it.
Old Sep 28, 2009 | 11:18 AM
  #37
db09JKU's Avatar
Why did this get moved? Oil change 101 would seem to fit better in Stock than Off road?
Old Sep 28, 2009 | 03:07 PM
  #38
TINMAN080's Avatar
why move this to OFF ROAD? Very confusing- it will guarantee no noobys will see it.....not bitchin', just asking...
Old Sep 28, 2009 | 07:06 PM
  #39
metro7100's Avatar
I went to my local Wal Mart and got 5 qts of 5W20 Mobile Fully Synthetic for $22.00. Single quarts were $6.50 each so I just bought two 5 qt bottles and a filter. Filter was $3.29 or $5.69 for the better one.
This is by far the easiest vehicle to change the oil on.
Old Sep 29, 2009 | 07:54 AM
  #40
db09JKU's Avatar
Will need to check there. Oil filter wrench? Any suggestions on that?
I still have a few miles before I need to change it, but I'm itching to do it! Can't wait.
