JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
Pushed my cluch in while submerged!
Old Mar 25, 2011 | 07:51 AM
The_Yeti's Avatar
I've done the same thing. I havn't had any problems I think it depends on if its just muddy water or large sticky mud/sticks ect.
I about $HIT myself when i had stalled it and hit the clutch and it wouldnt restart.
after being winched out i let it sit with my foot on the clutch to kindof let any water ect drian out and then started it let it idle in neutral. I would ligtly engage the clutch just enough to get it spinning and then let it dissengage to spin any crap off of it if there was any. that was last summer and i'm stil going strong about 20K miles since then.
Old Mar 25, 2011 | 07:13 PM
f3arn0FJ's Avatar
If it still grabs when you shift gears you'll be find, if it slips then flush'n change the fluid.
Youri is like the mud/water nazi so don't pay him any attention. Going by his know how, anything over 6 inchs of water/mud and you'll have to buy a new jeep.
How'd the diff. fluid look after the mud hole?
Old Mar 25, 2011 | 07:19 PM
StrokeHerAce's Avatar
Your not that deep man, I would say you will be fine.
Old Mar 25, 2011 | 07:22 PM
matt852's Avatar
I was stuck all the way up to the front bumper for a good couple ten minutes and I pushed my clutch in very similar water to you my buddy opened it up the next day and there was nothing wrong with it.
Old Mar 25, 2011 | 09:03 PM
kris003's Avatar
show more pics of that day
Old Mar 27, 2011 | 08:24 AM
medic_23387's Avatar
Originally Posted by TripleJeep_99
^^^ totally agree, don't touch that clutch if you have found no performance issues. I am sure there was very little to no damage to the clutch and the muddy water does not look to thick to be really concerned. Just stick a hose into the clutch housing and rinse it out. Also, I would not worry about the Tranny fluid you are not deep enough to go over the stock breather tube for the Tranny or Transfer Case in that hole, but you should consider extending your breather tubes (axles, tranny & transfer case) and next time you play in water and mud....4LO!!
End of wheeling season, that's when you can drain all the fluids unless contaminated.
Yeah I'm not going to replace it it is still working fine. I did change my diff oil the next day. It was in 4 low that pit is so much worse than it looks. It is that sloppy sloppy mud. when I got out everytime u stepped even on what looked dry you would sink to ur knew. Ask my wife she lost both shoes LOL. After I got pulled out they took a John Deere 4840 through it and it got stuck to. But all in all thank you for all ur post and help
Old Mar 27, 2011 | 08:28 AM
Was in 4 low it was a lot wise than I looks it was that really sticky mud. You would step on what looked dry and still sink instantly to ur knee. My wife lost both shoes. I'm sure those cost me a pretty penny LOL. after they pulled me out they took a John Deere 4840 through it and it got stuck too. Thank u all for ur help and insite.
Old Mar 27, 2011 | 08:29 AM
Sorry about the double post my phone messed up
Old Mar 27, 2011 | 01:05 PM
Battlefrog's Avatar
Originally Posted by mvnolan
The JK is perfectly capable of playing in the mud and water, just know your limitations. I have had muddy water to the headlights in mine with no problems. Is it a good idea to push the clutch? No. Will it always cause sever damage? No. Would I replace a clutch that is not giving me problems on just the opinion of someone I have never met? NO WAY!!! There is absolutely no excuse to send the OP's mind racing, thinking he has ruined his clutch, and that he should immediately sink hundreds of dollars into his Jeep for a repair that is not necessary. If it ain't broke, don't fix it.
X2... As long as you've changed the fluids and the clutch is not giving you any issues, I wouldn't put any $$ into fixing something that's not broken. Just continue to monitor it and maybe another Fluid change during your next oil change just to make sure their is nothing floating in there. If it was a serious issue, you would know by now.....
