JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
replace d-rings?
Old Feb 19, 2010 | 06:49 PM
stevedolce's Avatar
Default replace d-rings?
anyone replace the d-rings on their rugged ridge bumpers?
i'd like something that screws off easier. sorta like on a shackle. or is that a bad idea? are the d-rings stronger and i should just carry a wrench to take 'em off?
thanks
steve
Old Feb 19, 2010 | 06:51 PM
GoodysGotaCuda's Avatar
small crescent wrench is pretty handy for multiple uses. I have one of those and some good slip-joint pliers in my JK at all times.
Old Feb 19, 2010 | 07:01 PM
stevedolce's Avatar
hey goody..thanks.
i've started to carry a tool box in my jeep. i'm happy to un-wrench them if that's the smarted way to go. i've got a shackle attached to my trailer hitch and the unscrew pin is convenient.
is the general consensus that D-rings are stronger then regular shackles?
Old Feb 19, 2010 | 07:23 PM
The term D-ring and shackle can sometimes be tossed around as the same thing. Do you have pictures of what you are referring to?
Old Feb 19, 2010 | 07:40 PM
rome07JK's Avatar
i think he means these as apposed to these....
Old Feb 19, 2010 | 08:45 PM
horwitzs's Avatar
Doesn't look like it would matter to me. I think the D-rings on the bumper are wrenched in because they are meant to be there all the time.
The shackes that you screw in by hand are meant to be used and removed, otherwise they'll vibrate loose and disappear. Even when you use them you are supposed to turn them tight, then back off a little before tensioning on them, so they don't seize.
Old Feb 19, 2010 | 09:50 PM
Cedo Nulli's Avatar
I know teraflex makes/sells some shackle mounts I've seen used to replace the RR D-rings. There was a pic on here recently of someone who'd used Purejeep shackle mounts also and bolted right up.
Personally, I'm on a quest to find 12g carrage bolt that I can use with a pin or something to be able and remove the RR rings when I need to use them.
Old Feb 20, 2010 | 10:37 AM
rome07JK's Avatar
yeah i have the pure jeep shackle mounts on my bumper and not that i look at it you probably could take the one off the rugged ridge and use the pure jeep
Old Feb 21, 2010 | 06:12 PM
Why wouldn't you just use a shackle to hook up to the one on the bumper? Or attach your cable with the hook/shackle that is on the winch cable? New to this so just curious. Thanks for any explanations...
Old Feb 21, 2010 | 06:16 PM
stevedolce's Avatar
wonder if the PJ shackles fit the RR bolt pattern??
is there a strength difference between a shackle or D-ring?
