JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
Reverse Thrust
Old Apr 13, 2010 | 01:43 PM
earfixr's Avatar
Default Reverse Thrust
Anybody know if the manual transmission has thrust bearings set up for shock load in reverse? I know snatch/jerk strap pulling out a stuck jeep is always done best in forward gears but sometimes turning around in tight woods is a pain. And yes a winch is cheaper than a transmission but not always an option for everyone.
Old Apr 13, 2010 | 02:43 PM
ronjenx's Avatar
I would think stressing the backs of the ring and pinion gear teeth would be the limiting factor.
Old Apr 14, 2010 | 11:35 AM
Red's Avatar
Red
I agree with ronjenx, the diff is going to be the weak point in this equation. Though to answer your question, or to not really answer it, I don't have much information on the tranny. The dealership replaced mine, so I never had to tear into it and see what's going on in there. However, the off road words of wisdom I always learned is don't use reverse to recover unless you have to, because you risk damage to your diff. However, rule #1 was always it doesn't have to look pretty, it just has to work... once.
Old Apr 14, 2010 | 03:23 PM
jd1066's Avatar
And you would be correct Rojenx and Red! A picture speaks a thousand words - this is what happens when you shock load a 30 in reverse:
Yes, I know that a 30 is an incredibly weak axle, but bottom line - the strength in your R&P are in the forward gears.
I was backing up on a rocky trail and blew one of the spider gears half way through the cover. I wasn't on the gas hard - I just got the front driver's side tire hung up and bang! Needless to say, it also destroyed the ring and pinion, and blew a hole in the bottom of the pumpkin.
Just my $.02, but drive until you find a place to turn around - it's much cheaper than having to replace your entire axle.
JD
Old Apr 14, 2010 | 07:04 PM
Piginajeep's Avatar
JD
listen to the man with experience!
Old Apr 14, 2010 | 09:20 PM
ronjenx's Avatar
The "W" stands for "Who".
Old Apr 25, 2010 | 12:13 PM
ZoSo-Green's Avatar
On that note,
I disintegrated a tranny trying to jerk someone out in reverse. (Pre JK, 700R4)
Not a good idea, I will always find a spot to turn around.
Old Apr 26, 2010 | 11:41 AM
Detonatorunlimited's Avatar
Those replies and pics should be enough so i will never, never tow someone out in reverse:beer dont want to turn my diff into a grenade.
