JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
So much going through my head! HELP LIFT MY JEEP!!!
Old Nov 28, 2015 | 03:25 PM
  #31
igobytony's Avatar
Originally Posted by WranglerBoss
I get that. My question is will the factory 17" wheels with the factory Goodyear Wrangler tires fit after installing the leveling kit.
If you have factory wheels, and factory tires, they'll fit just like it was from the factory. A leveling kit is just going to slightly raise the rest of the Jeep from the axle, not do anything that affects wheel backspacing, or add parts that will be in the way of stock setup.
A leveling kit is just a little booster on top of the coil spring, in case you didn't know.
Old Nov 29, 2015 | 07:23 PM
  #32
WranglerBoss's Avatar
Will a 3" leveling kit give the same look as a 3" lift kit?
Old Nov 29, 2015 | 07:29 PM
  #33
BlackRockBurner's Avatar
Yes. Both lift the jeep. How much is a variable that has variables.
Old Nov 29, 2015 | 08:04 PM
  #34
Lol sorry! I'm new to this so I'm trying to get everything straight and right before doing it.
Old Nov 30, 2015 | 05:41 AM
  #35
TheDirtman's Avatar
We can tell, lifting and running the factory tires only degrades the drivability and performance of the jeep and otherwise makes it look funny. You will get a better breaker angle for those steep climbs.
Old Nov 30, 2015 | 11:46 AM
  #36
I'll eventually get new shoes but the Jeep build is going to be a long process for me. I'm just going to have to do it all step by step.
Old Nov 30, 2015 | 11:49 AM
  #37
With the leveling kit in the link below, will I need any additional parts like sway bark links or anything or is everything in the link below all I need? Also, will I need an alignment after installing?
http://www.4wheelparts.com/Suspensio...t_pn=EXP66150K
Old Dec 12, 2015 | 04:51 AM
  #38
Rgk401's Avatar
With the leveling kit in the link below, will I need any additional parts like sway bark links or anything or is everything in the link below all I need? Also, will I need an alignment after installing? http://www.4wheelparts.com/Suspensio...t_pn=EXP66150K
Yea I would do a alignment after.
Old Dec 15, 2015 | 10:14 AM
  #39
Got it! Thanks a lot everyone! You've all be super helpful!
