Sway bar disco
Sway bar disco
Ive never had any before but I have a 2012 Rubicon on order. Just wondering if you can only use them when in 4lo or if I can use them anytime im off road
One more ? If the swaybar light is flashing that means that it still has not disconnected right. When I have the jeep on an in 4 hi or 4 lo and push the disco button the light just flashes and never goes solid. Am I I missing something sorry I'm new to disos but not jeeps. Thank
The flashing light indicates the disco doesn't agree with what has been requested.
If you request disconnect, it will flash until it disconnects.
When the sway bar is under load from being on uneven ground, it will not disconnect until the load is relieved.
If you request reconnect, it will flash until it reconnects.
When the sway bar is disconnected and displaced from being on uneven ground, it will not reconnect until the internal splines line up.
The sway bar will disconnect in 4lo and 4hi, but will attempt to reconnect over 18mph. It will attempt to disconnect again once the speed is reduced to below 14 mph.
