Tire Air Down Guide?
We're usually 12-13 psi here on the rocks. It depends on the tire width, rim diameter, beadlock, terrain, weight of vehicle, tire load rating, etc.
It's usually either ask others who are doing what you're doing, or try it out yourself. I've lost one bead at 13psi because i hit it just right on a rock. No biggie with the co2 tank to take care of it.
1) Get on the stuff you want to be airing down onto...a rock, sand, whatever. Measure your rim to ground distance (Sidewall height - a stick, your hand, any handy reference point)
2) Start letting air out, while watching your sidewalls and tread area.
3) When the tread area on the ground stops getting longer and wider, or, when your sidewalls are bulging out so that less of half your sidewall height remains, stop. (You are on a rock for example, and the tread will start to wrap around it...when its as wrapped as it going to get, and losing more air will simply mean you have a flatter tire, stop) Etc.
4) If you have street oriented tires, AT's, thiner walled tires, etc...you may find that you need to addd a some air back in to keep the tires from coming off the beads. Use your sidewall height as a reference, so you will REMEMBER what that is.
5) If you have thicker sidewalled tires, they can run typically with less pressure than the thinner ones. As every tire and jeep is a bit different, there IS NO one magic "Right" psi.
The guide is as follows:
Thanks, that explains everything.
