JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
Tire Deflators
Old Sep 18, 2011 | 08:21 AM
T&ERun's Avatar
Default Tire Deflators
Anyone use the Smittybilt deflators? They look a lot like the Staun deflators but much cheaper. If you have the Smittybilt how do you like them? I know the Staun's are good. Here is a link for both.
http://www.quadratec.com/products/pr...h.php?kw=staun
Old Sep 18, 2011 | 08:38 AM
greenenvey's Avatar
I've heard that the staun lookalikes don't work very well?? But I have no experience with them to back that up!!! I'm sure someone will have them and let you know how they are. I bought stauns after a guy on the trail let me use his, I really like them
Old Sep 18, 2011 | 08:54 AM
Mixilpidilstick's Avatar
I have used both. Staun are much better.
Old Sep 18, 2011 | 09:38 AM
T&ERun's Avatar
Thanks. Looks like it's stauns, but from Northridge. Much better price.
Old Sep 18, 2011 | 09:47 AM
Fenrir's Avatar
I have the smittybuilt ones. The one time I used them to set the PSI, they seemed to work fine.
I need to try them again before I give them an accurate review.
When I used them the first time, I was expecting that the air would come out of the tire at a good rate of speed. When it came down to the last PSI to evac the tire (I had it set to 18 PSI by using them on the Spare first) I felt that they stopped working. The PSI was around 22 - 18, depending on which tire I checked. This could have been because I wasn't calibrating the deflators properly.
Even if they don't work "Perfectly" had I calibrated them precisely, it sure beats airing down each tire one by one with one tool.
Old Sep 18, 2011 | 10:55 AM
donnie's Avatar
From: Simi Valley, Ca., Taylorsville, Ut. and places in between
When I was looking for a deflator, I went with the one from Currie.
Have used it several times and like it a lot.
http://www.quadratec.com/products/95202_402.htm
Old Sep 18, 2011 | 04:51 PM
genesbro's Avatar
I just use those clip on tire inflators with the airhose atachment on it for easier handling as my deflator. Very inexpensive and does it quickly. Not automatic but I don't care about that, I just use a digital gauge to check when I think they are getting close and I have done this enough times I have a pretty good idea when to check.
Old Sep 18, 2011 | 05:08 PM
08JKRHD's Avatar
X2 quality product!
Old Sep 19, 2011 | 05:18 AM
Cunnart's Avatar
I have the stauns and love them. I have a buddy with the smittybuilts and he said he cant get them to work right.
Old Sep 19, 2011 | 08:04 AM
BKGM Jeepers's Avatar
I've owned the smitty builts and donated them to my club raffle. I own the Stauns and also own the cheap, non-stop deflators. I would run these over the smitty builts. The smitty builts wouldn't stay consistent with me. They always deflated to different pressures in the 2-3lb difference range. That may not seem bad but when you go to 9, 6 is too low...
