Tire Deflators
A deflator that does one tire at a time? You are the people I wait for each time I air down. At least it gives me more time to hang out and talk. BTW, you can even drive (in 4-lo on the trail) with the Staun's on and check them after 4 minutes.
Technology is a great thing, be sure to take advantage of it.
I have the smittybilts and like them well enough. They are noisy as they make a humming sound. That said, I only use them once a month max. For me, it wasn't worth paying more.
Mine have been pretty consistent. I did find that you can't screw them down tight. If you do, they take forever. If you loosely put them on, they work much better.
You seem very hostile about tire deflators....
Originally Posted by donnie
When I was looking for a deflator, I went with the one from Currie.
Have used it several times and like it a lot.
http://www.quadratec.com/products/95202_402.htm
I have the same one but several manufactures have the same design. A friend of mine has the stauns and they take about the same amount of time. This deflator removes the valve core but keeps it enclosed in the tire gauge so you can check/stop the process at anytime.
