Transfer Case Shifting
So I've read the Jeep manual, and believe this is what they were attempting to say:
Shift from 2H to 4H: Any speed up to 80Km/h, no need to depress clutch or be in neutral.
Shift from 4H to N to 4L: 3-5km/hr roll, depress clutch, shift to neutral, then shift to 4L
Did i interpret this correctly? Just want to make sure that I don't need to use my clutch to change from 2H to 4H, the manual didn't say to, but that surprised me so I wanted to check.
Thanks!
Thanks!
You're pretty much on the money. You can shift on the fly so to speak anywhere up to 60mph(US) and no need to use the clutch. Shifting into 4LO you just need to rolling at a few KM/hr in neutral to make that shift.
One piece of advice since it sounds like you just got your Jeep. Don't force the transfer case shifter if you're having difficulty getting it into 4LO or else you'll break the linkage.
Good luck!
Good luck!
Yep, new to Jeeps - and loving it!
And that's without even having had the top/doors off yet (too cold here) or having been off road yet.
Thanks for the responses, I just had to make sure so I don't do anything stupid.
And that's without even having had the top/doors off yet (too cold here) or having been off road yet.Thanks for the responses, I just had to make sure so I don't do anything stupid.
Just a quick note though; if you're rolling & the transfer case grinds loudly when you try to shift out of 4-low, it means you're moving a little too fast. Should only be just moving when you do it; I usually do it stationary on a slight incline, & just roll forwards or backwards slightly to let the gears mesh or disengage.
I'm learning it's an art to shift into 4LO w/o the grinding. There is a sweet spot for the right amount of momentum, not to much but just enough to make the shift nice and smooth. I talked to a buddy of mine in my club about it and was told not to worry to much about it. The grinding sounds much worse than it really is. I tend to listen to him as he knows his way around a Jeep very well. I tend to believe that as I've heard that from others as well. The trick is not to try and force the shifter, because when you do you end up breaking that linkage connecting the cable to the transfer case.
Not with my Jeep. If I do it, I hear an awfull noise I have to be at zero mph and it's just perfect. I don't understand why my JK is like that.
The slower you go to get into 4 low the better, you really do want to keep it below 5 mph. Also, when shifting out, it can kinda be a PITA, but again stay slow and youa re good.
As far as shifting to 4 hi form 2 hi, you can do that at pretty much most speeds, but I am always sure to be under about 20mph. Mostly only use it (if necessary) in snow or when doing mild muddy trails...
