JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
What to do AFTER wheeling
Old Jul 8, 2008 | 03:43 PM
cadmanaz's Avatar
Default What to do AFTER wheeling
I like to wheel and am still learning alot about what my JK can do.
What should I do after wheeling?
I'm pretty much in dry desert territory and have noticed a few more squeeks and rattles after coming back home and driving around town. Are there certain areas I need to keep regularly lubed. I do wash the JK real good (especially the dust in the radiator fins).
My trails generally are easy-to-moderate level. See my signature for my setup - pretty much stock. And I disco the front.
Any thoughts would be helpful!! Thanks!!
Old Jul 8, 2008 | 04:05 PM
User 12721's Avatar
Most (if not all) of your stock suspension uses rubber bushings at the stock suspension joints, but if you really had to, you could take a grease needle to all of the parts that see the most work when you go off roading (e.g. control arms, track bars, sway bars/ links, lower shock mounts, etc.). It would also be a good idea to go over all of those parts and take a wrench, or torque wrench to them to make sure none loosened up, and also to look over to see if anything was damaged.
Old Jul 9, 2008 | 05:18 AM
jkkat's Avatar
After every run i due an after wheelin roll around. It is an inspection of the whole under carrage after washing it and before going any where else.
Old Jul 9, 2008 | 10:34 AM
LOST's Avatar
I always do a quick undercarrige inspection before I get on the highway after wheeling.
Sticks caught in springs or brake lines, big clods of mud inside the rims, mud caked radiator and debris on top of the cat are the most common things I look for.
As always check for leaking fluids and tire damage.
Old Jul 9, 2008 | 10:59 AM
Big Clint's Avatar
First thought after reading the title of the thread is to get a or .
Old Jul 12, 2008 | 06:47 PM
mmcan's Avatar
As a doctor, I would recommend at least 2 cold beers in your favorite flavor.
And repeat prn.
(prn = as needed)
Old Jul 16, 2008 | 08:32 AM
robin's Avatar
I thought abot the same thing, we usually get a couple of beers after wheeling.
Old Jul 16, 2008 | 12:53 PM
Big Clint's Avatar
Originally Posted by Dayton
Well, after a recent trip in which I was the last in line - I did this when I got home:
Grabbed a Tecate from the fridge.
Checked my trans fluid, because I got the phantom DING again. Check all of the other fluids.
Grabbed another Tecate.
Turned on my air compressor and blew out 27lbs of trail dirt (found Jimmy Hoffa).
Power washed the JK and parts of the engine (still has mud from Trabuco).
Greased and tightened all control arms and track bars.
Pulled my CB antennae off my back bumper and threw it away.
Grabbed the last Tecate. Damn...
And that's about it.
The lesson here is that when the Tecate runs out, the work must stop.
Old Jul 17, 2008 | 11:06 AM
txraistlin's Avatar
If you go near mud at all, and you disconnect, I would highly recommend thoroughly washing off the connection points and making sure the bolts and nuts are clean before reinstalling. Re-check when you get home too as they tend to loosen up as did mine. Mine got a little grit in them during re-install, no water to wash off at the time, drove home forgot about it. Till my next w/e when I spent 3 hours trying to break the galled bolt loose and finally gave up on disconnecting. Ordered the Teraflex quick disconnects that night (this last Friday) and they should be arriving in a few days at which point I get to chop the old bolt off!
Old Jul 17, 2008 | 11:40 AM
Big Clint's Avatar
Maybe we all forgot a step...BEFORE heading for the 's at your local establishment, re-connect your sway bar links. If you don't, you may feel like you've already had a few before you get there.
