1 ton jk build
Old Mar 2, 2012 | 04:37 AM
  #141
Tank29's Avatar
Originally Posted by TexsDream77
My Ford front axle is from an '03 F-350 and is about 4" wider than the stock one. WMS-WMS Considering I was running the 1.5" wheel spacers for a total of 3" wider like most of us do, the axle fits great.
Well that is good to know it is only 4" wider...My only issue would be our state inspection requires complete tire coverage so my flares may not cover it unless I can get wheels with less(?) offset...Thank you for the info...
Old Mar 2, 2012 | 10:08 AM
  #142
Tank29's Avatar
Here is what I'm finding in my area (within 100 miles)...What do you guys think???
2002 Front Axle Assy. Ford Truck F250 Super Duty 3.73 w/Manual Locking Hubs 70,000 A HA039 $500
2003 Front Axle Assy. Ford Truck F350 Super Duty 3.73 49,146 A GA124 $650
2004 Front Axle Assy. Ford Truck F350 Super Duty 3.73 w/Manual Locking Hubs + Stabilizer Bar & Track Bar [No Steering Rods] 45,000 A HA189 $650
2002 Front Axle Assy. Ford Truck F250 Super Duty XLT,12-01,5.4,AOD,4x4,ABS 116,028 A 11G028 $500
2003 Front Axle Assy. Ford Truck F250 Super Duty XLT,1-03,6.8,AOD,4x4,ABS 134,588 A 10G029 $500
2003 Front Axle Assy. Ford Truck F250 Super Duty 8-02,5.4,AOD,4x4,ABS 94,864 A 10H019 $500
2002 Front Axle Assy. Ford Truck F350 Super Duty 4KC4,AOT,3.73 35,963 A DH1046 $550
2003 Front Axle Assy. Ford Truck F350 Super Duty (4 whl ABS), SRW, 3.73 ratio 11 067 $650
Old Mar 2, 2012 | 11:56 AM
  #143
350ssindigo's Avatar
Hi , I'm planning on upgrading to 60 s , I know that the best axle is the front ford f350, from '99-'04 , I have 1 f-350 dually and 1 f-250 single , from '05 - '07 , if I shave all the bracket and housing , will it fit , and what is best for the rear , gm full float 14 bolts or ford f-350 ?
Old Mar 2, 2012 | 08:26 PM
  #144
TexsDream77's Avatar
The F-250 has a very simular axle but has a D-50 center section. You can tell right away because the pinion nut is tiny on the 50 as compared to the 60. You want a 60 so you need an F-350. I'm unsure if the mearsurements are the same on the front from knuckle to knuckle on the F350 single and dual wheel trucks. I know I used a single wheel truck and ended with modified dual wheel front wheel bearings and stubb shafts.
Old Mar 2, 2012 | 08:28 PM
  #145
FYI: The 04 F-350 is different than the 99-03. The '05-'07 is different as well.
Old Mar 3, 2012 | 07:13 PM
  #146
What is the difference on the '04 ? Is nt it spring mounted like the 99-03 and not like the coil spring type like the 05-07
Old Mar 3, 2012 | 07:20 PM
  #147
I'm not sure what all the differences are. If you order parts for them, the '04 is seperate. The seals have differnt part numbers at our shop. I know the frames of the trucks are different. When we install a snowplow, it is a stand alone year as well. I don't know for sure that there is any problem with it, I just don't know for sure that there isn't. The Ford Superduty versions run '99-'03, '04, '05-'07, '08+ ('11+ on the diesel is different too).
Old Mar 3, 2012 | 07:26 PM
  #148
Could I use a 05-07 front housing on my jku ?
Old Mar 3, 2012 | 07:33 PM
  #149
Unlimited5.7's Avatar
F-250s came with the 60 also. Just that some in the 02-03 era came with the Dana 50. You can search numbers and it's easily identifiable.
If you could pick up even a 50 for a super cheap deal I wouldn't be afraid to run it. You still get the monster housing and giant shafts.
Old Mar 4, 2012 | 05:14 AM
  #150
I don't see why not. It's never been done before to my knowledge. The '99-'03 is easy because that is the axle Currie uses for thiers. So you can buy the parts to bolt on to make it work esp/abs compliant.
