1 ton jk build
Old Apr 23, 2012 | 06:59 AM
  #161
kalopoulos's Avatar
great build.
Old Apr 23, 2012 | 09:10 AM
  #162
quinnfrontz's Avatar
glad to see someone has a build thread on this. Im about to pull the trigger and start my 1 ton build. i feel like with all the money i spend fixing my damn axles i could have ordered rock jocks haha. do you have to do the spyntec kit to have wheel speed sensors?
Old Apr 23, 2012 | 04:39 PM
  #163
EAZY-E's Avatar
http://www.jkowners.com/forum/showthread.php?t=64585
Old Apr 25, 2012 | 08:00 AM
  #164
B U R T O N's Avatar
Subscribed…… Excellent….
Old Jul 29, 2012 | 11:02 AM
  #165
Unlimited5.7's Avatar
Is it possible to run the factory tank and the sterling rear?
How are the road manors with the front 3 link?
Nice build!
Old Jul 31, 2012 | 07:28 PM
  #166
Nice build!
Bump. Anyone know? Looks more like I need to pick up a 14 bolt
Old Aug 1, 2012 | 04:38 AM
  #167
Garald_JK's Avatar
When I was researching the Sterling install I emailed RedX08 and asked this same question. His advise was yes it can be done. If you Heat and Beat the tank corner and modify the sheild a little.
Old Sep 30, 2012 | 05:24 AM
  #168
Blade's Avatar
I just aquired some 02 Ram 2500 Dana 60s, would I be able to use these, as I see most of you guys are using the Ford axles.
Old May 28, 2013 | 02:25 PM
  #169
wildace's Avatar
Originally Posted by redx08
Check out jeep speed shop, they have a jk tone ring that will go on the hub of a 14 bolt. They also make a bracket that holds you sensor. This will make your pocket book happy. I could have gone with a unit bearing on the front 60, but i rather have a hub and spindle and just put new bearings in when i need to. I am not a fan of unit bearings.
i just checked and couldnt find them on there. do you have a part number?
Old Sep 21, 2013 | 05:49 AM
  #170
HiHoSilver's Avatar
Pm'd about this! Great build!
