14 bolt conversion
Old Nov 22, 2011 | 04:38 PM
Curiosity's Avatar
Originally Posted by EAZY-E
For the hubs, I like the spyntech hubs, to convert to 5 lug and narrow the width by 2.25". So width should be .25" wider than stock? (Could be wrong). For the Tone ring I am looking toward the river raider kit. Mostly because I havent found another kit. Im still researching.
$400 hubs
i think i read somewhere that jeepspeedshop makes tone rings for the 14bolt rearends.
Old Nov 24, 2011 | 01:46 AM
HeatTreater's Avatar
Already started my 14 bolt swap I got lucky mine came out of a miliarty truck so it has a Detroit locker already so just a gear swap and some brackets my problem is going to be running a triangulated 4 link in the back which means relocating the gas tank.
Old Nov 24, 2011 | 03:02 PM
EAZY-E's Avatar
Are you keeping all the electronics? If so what kit are you using? Any chance you made a build thread?
Old Nov 24, 2011 | 05:42 PM
dlincoln91's Avatar
jeep speed shop makes a kit thats like $200 and riverraider makes one thats like $1700
i would not reccomend the riverraider kit. i ran it on the front and the engineer of the kit didnt really do that great of a job. the brakes had to be changed up and they didnt really know to much of the kit let alone what brake calipers went with it so i bought the wrong ones. also its extremely over-priced. all it is is tone rings and 2 brackets with some half ass hubs that they dont add in the price. so you either pay for new ones or pay for used ones.
Old Nov 24, 2011 | 05:48 PM
dlincoln91's Avatar
also $1500 is a little cheap your looking at
200-housing
200-jeep speed shop kit
600-detriot
450-ring pinion and install
400-brakes and calipers(can vary)
450-brackets
$$$-custom trackbar and other things probably going to be needed for custom work easily 800 in that
450-driveshaft
$$$-wheels for new bolt pattern
When i did my front 60 with coilovers i thought it would cost just around 6200-6400 but with the extra cost of extra things needed and new steering arms,trackbar, and brake stuff it went to about 7800.
its still cheaper than a dynatrac and i feel like stronger since its a kingpin
when i do my 14 bolt im looking to spend probably 3-4 grand and thats with everything and running
Old Nov 25, 2011 | 05:11 AM
Nudge's Avatar
Here's an Aussie doing a 14 bolt rear end conversion
http://www.aus*********.com/threads/...-JK-conversion
Old Nov 25, 2011 | 05:48 AM
I don't know just yet about electronics still on the fence.
No thread yet just getting all my parts together first and see what happens.
Old Nov 26, 2011 | 07:01 AM
JK on 44s's Avatar
You guys realize the newer style super duty sterling 10.5s are pretty much $50 away from being plug'n'play with the tone rings/electronic. IMO they are a much better option for a one ton converision on the JK for that reason. They are equivalent to a D70 with a 10 1/2" ring gear and 35 splines as is. If you guys want to upgrade your rear for cheap and still keep you electronics then this is the way to go. Heres my buddies rig who did the swap. NO lights on the dash at all.....
Old Nov 26, 2011 | 05:10 PM
dlincoln91's Avatar
what exactly do you have to change on the sterling 10.5s to get electronics going. also what year are they coming out of and are they hard to find? also is the bolt pattern 8x6.5?
Old Nov 26, 2011 | 05:48 PM
Jeff76's Avatar
Why would you use a 14 bolt and convert it to 5 lug? I'd keep it 8 lug and just run 8 lug wheels.
