14 bolt conversion
Ford has been using sterling axles for a long time. It should be pretty easy to find one out of a late model truck. Only downside is that lockers are expensive and there arent many to choose from. I know detroit and arb make one. Bolt pattern is 8 on 170mm. I'm using this axle in my build. Not sure what it takes electronice wise..
Originally Posted by Jeff76
Why would you use a 14 bolt and convert it to 5 lug? I'd keep it 8 lug and just run 8 lug wheels.
Hello all.
I am really interested in this 14 bolt axle swap for my 4 door. My original plan was to put dana 60's front and rear. But I am getting a 14 bolt FF for way cheap. Like 150 complete. 75 with trade. So i started doing some searhing. I am still foggy on this conversion. I would like the 14 bolt to be at leat 5 on 5.5 because i just bought wheels 2 weeks ago. Yeah should have thought more about it but whatever.
I have read the aussie that has put one in the jk, but it was 8 lug still.
So what I am trying to find out before i get this rear is there a 5 on 5.5 hub with tone ring that will work with the 14 bolt? All the ones i have seen are 35 spline for dana setup not 30 spline setup for the 14 bolt.
Anyone got any info on this? Should i just stick with the d60 idea?
Originally Posted by Garald_JK
Hello all.
