200lbs tounge weight for 2dr jk?
ordered the rugged ridge trailer hitch the other day, got it yesterday. went to put it on at work this morning and realized the tounge weight is only 200lbs. i bought the hitch specifically for a cargo basket that goes into the hitch. it weighs 34lbs so that leave only about 166lbs of tounge weight left. is that enough? is 200lbs tounge weight average for the 2door???
The 200 limit is for tongue weight for a trailer. The inertia of a trailer acts differently than static weight. The difference between the 2 and 4 doors is only the wheelbase. You can easily place 350lbs. or more on the hitch and mounting area. The handling will be no different than if you have a couple of large people in your backseat. That said a 150lbs of camper gear is a lot of stuff.
It is different. 350 lbs. on a rear rack will lighten the front end more than the same weight behind the back seat.
You are absolutely right. Who was it that said; give me a lever long enough I’ll move the world? In theory if you moved the weight back far enough the jeep would do a wheelie.
